Piston knock on 301rr?
bobb
I’d be checking the internal diameter of the con rod small end. Even with the slightest play it will give a knocking noise. The piston doesn’t do much other than support the rings, which do all the hard work and wear considerably. If the con rod is slightly out of specification everything will wear as it won’t be runnng true and it will do the same again
Edited by jrsunt
3 hours ago, bobb said:
Lemur what do you mean with jam sandwich?
When a piston ring pack becomes gummed up from bad fuel the rings stick in the piston grooves, then everything starts to go badly. Once you experience it you will know why I call it a jam sandwich.
On 12/20/2025 at 9:02 AM, lemur said:
You sure you want to hone a plated barrel 🤔 don't think you are suppose to do that.
I've had a few plated dirtbikes & have given them a light hone before installing a new piston & rings, i know a lot of other Blokes that have done the same, as long as the mechanic has the correct tool & knows what he is doing there should be no problems.
So you are scratching up your fresh new spray coat of ultra hard nickel and silicon carbide that is actually harder then your piston rings for what purpose 🤔
  • Confused 1
It's to prepare the cylinder surface for the new piston & rings plus it helps with lubrication :)        They are given a hone before their first use with a diamond stones hone, most good mechanics have 1 in their assortment of tools .
Edited by eagle8
  • 1 month later...
