Return of the “what transmission oil”
Nishijin
Hi all,
Bought a 2016 300rr and the dealer put 10w40 tranny oil in it. Not Elf.
Took for a practice. Felt fine until hot-hot and then refused to find any gear except the one it was in, had to turn off or wait until cool.
Prefer not a light-switch clutch. What was the decision after the past decade since people chatting GRO?
I find it hard to believe 10W40 oil could cause that malady.
Me too but I’m trying to do the simple things first, like changing oil, before kicking a fuss with the dealer it came from.
Practice area was mild, not overly hot, mid-evening (UK, so 20° maybe more). Easy rolling practice around some trees on a slope. After a short while it was getting tough to change gears. After an hour it refused to change and refused neutral unless off.
After riding down the lane back to the van and the bike being a bit cooler, it would shift a bit easier.
Off and cold, the shifting feels a bit clunky but monts are new to me (vs the ‘83 TLR, ‘16 Sherco, and all the trail and road bikes).
Kubota Premium UDT Hydraulic/Transmission Fluid specifically formulated for transmissions with wet brakes as well as power steering and power takeoff units with wet clutches 👍 At a small fraction of the cost of what those other guys use, I can change it out twice as often and still save money.
The 10w40 should be more than up to the job unless it’s very poor quality. These things will happily change up and down without the clutch just by matching the revs. My gearbox is 20 years old and never been touched!!
I have always found 10w40 to stand up better to heat and more abuse than Elf and light gear oils. The lights ALWAYS give a better clutch when cold but they get very grabby and snatchy when working hard. I run Motul 300v factory line for both engine and gear box. **** when cold, but isn’t affected by heat and hard riding.
Another thing with the Mont clutch is that you generally need full pull of the lever to find neutral. Any fingers between the lever and bars makes finding neutral tricky. Using the short lever helps, then it’s just 1 finger right at end next to the ball.
Edited by jrsunt
  • 4 months later...
I had an identical issue with my brand new 301RR.
On laps 3&4 of a trial, where I wasn’t stopping to look at sections, the gear change was terrible and at times the bike felt locked into one gear.
I couldn’t find neutral with the engine running while waiting at sections and if I stopped the engine, I couldn’t start it again when it was hot.
I adjusted the tappets which cured the hot start issue (these really do need doing after the bikes first run in and every 6 months after).
I did the washer adjustment on the rear of the clutch basket which massively improved the gear change, especially when the engine was hot.
The washer needs adjusting every few months and I’m yet the find a way of stopping the free play (it’s only about 2mm) but it massively affects the gear change.
Edited by beta rider
