Montesa301 Posted 5 hours ago Share Posted 5 hours ago Morning, I’m looking for some help with my Montesa 301 RR 2022 clutch. I’ve had issues with the clutch since purchase a year ago. It’s progressively got worse with juddering, shrieking when hot and now a grinding sound under engine breaking. Ive changed the plates out for Mitani Alluminium discs, fresh HTX 740 and it hasn’t improved or changed at all. Any advice would be much appreciated. Quote Link to comment Share on other sites More sharing options...
lemur Posted 1 hour ago Share Posted 1 hour ago From a site that sells that expensive lubricant: "ELF HTX 740 is a monograde ultra fluid transmission lubricant specially developed for dry clutch gearboxes coupled to 2-stroke engines. " I would try something cheaper that you can change out every time you get water in it, nothing will make your wet clutch act up and make noise as bad as having water in the oil. It's not the steels that are causing a problem it's your cork and/or paper friction plates. Quote Link to comment Share on other sites More sharing options...
jrsunt Posted 53 minutes ago Share Posted 53 minutes ago (edited) Get rid of the Elf, it’s great when the bike is cold but can’t handle the heat of a properly used 4rt. Use the same 10w40 that you use in the engine. I also run the Mitani clutch. Try that first, if it doesn’t help then something else isn’t right. Edited 48 minutes ago by jrsunt Quote Link to comment Share on other sites More sharing options...
lemur Posted 41 minutes ago Share Posted 41 minutes ago Kubota UDT or similar farm tractor and excavator hydraulic oil 👍 at about 10 bucks per litre works out to ~5 bucks per oil change. Extensively tested for over 2 decades and 5 Cota' ... your transmission does not require multiple-grade engine oil, it has far more in common with a farm tractor transmission that contains hydraulics, gears and wet brakes and wet clutches. If you think your motorcycles transmission oil is under higher stress then a farm tractor or excavator would experience you would be wrong. Quote Link to comment Share on other sites More sharing options...
