uhoh7 Posted May 22, 2006 Share Posted May 22, 2006 Forgive my ignorance... I have been riding my 06 300 pro a couple of times a week. Never had a gasgas before. It's running well here at 6000ft. I notice the gears have a sound all their own. 1-3 sound normal; 4th has a nice wrrrrrrrr, then the shift from 4th to fifth has quite a clunk even with the clutch in. Shifting at higher RPM gives a more elabaoate clunk. 5-6 both sound fine and the shift seems fine. Is this sort of normal? WHat about that clunk going into 5th. What is the best shift technique to take it easy on the transmission? I'm starting to think I should shift into 5th at as low rpm as possible. TY sirs Quote Link to comment Share on other sites More sharing options...
beta-boy Posted May 22, 2006 Share Posted May 22, 2006 hey i've had my 05 pro for almost a year now and i've asked the same question about a million times, and i've talked to all the champ class riders who ride the pros, and thay all say the same things, its a gasgas they make noises, and they all clunk into 5th its all good Quote Link to comment Share on other sites More sharing options...
scrappington Posted May 22, 2006 Share Posted May 22, 2006 the clunk from 4 to 5th unfortunately is normal they all do it but its no detrement to the gearbox nothing to worry about. Quote Link to comment Share on other sites More sharing options...
scrappington Posted May 22, 2006 Share Posted May 22, 2006 bit like this (sorry not a good pic) Quote Link to comment Share on other sites More sharing options...
cdn280 Posted May 22, 2006 Share Posted May 22, 2006 I've been trying to find a happy rpm to shift into 5th, I think it may be best at lower rpm. The huge gap in gear ratio doesn't help the situation, for both the clunk or for trail riding. I think the standard model's gearbox makes it a better choice for trail work. The price we pay for having 4 low gears to choose from, and to save some weight I guess. Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted May 22, 2006 Share Posted May 22, 2006 i find mine goes in better with more revs/speed well not revs but if ur goin pretty fast on the brink to change to 6th..obviously dont pagger it in 5th. Quote Link to comment Share on other sites More sharing options...
uhoh7 Posted May 22, 2006 Author Share Posted May 22, 2006 thanks guys...a relief... I suspected this was the case---"they all do it" Now here is another question: on the SSDT site I was ready the "get your GG ready thing" where it says something like: "you will have to use the choke for roadwork" is this to save the motor? Quote Link to comment Share on other sites More sharing options...
gasgas Posted May 22, 2006 Share Posted May 22, 2006 Uhoh, do a search in this gg forum with:engine (or something like that)and try to find my topic. There is a pic of the gearbox internals. Quote Link to comment Share on other sites More sharing options...
uhoh7 Posted May 22, 2006 Author Share Posted May 22, 2006 (edited) out with my KTM coupla days ago. Still lots of snow--- these are southern exposures Edited May 22, 2006 by uhoh7 Quote Link to comment Share on other sites More sharing options...
uhoh7 Posted May 22, 2006 Author Share Posted May 22, 2006 That's what I was wondering. Since I will be riding on trails quite a bit, what are the best tactics to avoid siezing? low or higher rpm? should I use the choke on the trail at all? Quote Link to comment Share on other sites More sharing options...
kinell Posted May 22, 2006 Share Posted May 22, 2006 That's what I was wondering.Since I will be riding on trails quite a bit, what are the best tactics to avoid siezing? low or higher rpm? should I use the choke on the trail at all? <{POST_SNAPBACK}> One of the big no-no's is holding the throttle on a steady rev. Keep rolling off and feeding it back in again... Quote Link to comment Share on other sites More sharing options...
perce Posted May 22, 2006 Share Posted May 22, 2006 also fit a bigger float valve in the carb as this also helps chuck more gas into the system Quote Link to comment Share on other sites More sharing options...
