Bleeding Brakes !
#1
Posted 03 May 2007 - 09:59 AM
Well I am still trying to get my ebay purchase out of the garage........ but I have learnt loads of things about working on trials bikes so not all bad.
Latest problem is that I cant get the front brake to work. I have bleed it using every method I can think if gravity, sryring and pressure. But nothing seems to work still very spongy....
Any ideas?
Cheers
Andy
#2
Posted 03 May 2007 - 11:50 AM
#3
Posted 03 May 2007 - 06:21 PM
scorpa3, on May 3 2007, 12:50 PM, said:
sort of, I pushed them in but did'nt wedge them in place and bleed. I pushed them in then just bleed them I will try your idea......... if that does not work is off to the local dealer!!!! Just want to ride it now...
#4
Posted 04 May 2007 - 02:51 AM
#5
Posted 04 May 2007 - 03:15 AM
Another method is attach a hose the the caliper bleed screw and run it to a container. With the cap off open the bleeder screw about 1/4 to 1/3 turn. Then smoothly pump in steady strokes and watch the fluid coming out of the (clear) line. Some times you can pump fluid through like this in a steady stream and it will remove the trapped air. When complete hold the lever in and close the bleeder screw qiuckly. This is the method we use to change the fluid.
#6
Posted 04 May 2007 - 06:04 AM
Reverse flush:: Syringe fluid through caliper and up and out of the reservoir. Messy so use rags.
Bleed:: Attach clear tube to caliper nipple and have it go into a half full clear container of brake fluid. Pull clutch lever in while opening the nipple. Close nipple before you let go of lever. Top up reservoir with fluid as you go. Do this steadily and take your time. PS. You do feel like you need 6ft arms or a blonde assistant .
Bleed the banjo union:: Sometimes you need to loosen the banjo at the reservoir and reverse syringe fluid through the caliper. Messy.
Use harsh language:: Shout at the f*kr and then set light to it.
Chief Mechanic and Coach to MoToToM
____________________________________
MoToToM is a Procycles KTM Race Rider
Proudly Sponsored by
Procycles Alpinestars Fox
Sherco 50 Kid
Beta Rev50
Sherco 2.9
KTM 50SX
KTM 65SX
KTM 990 Adventure
Sydney
#7
Posted 04 May 2007 - 10:35 AM
I've never done that to a bike but I lost a computer and a DVD machine in a similar fashion. Not involving fire but an upstairs window and a concrete patio. Beware..... using this method to fix your bike won't work well!
#8
Posted 04 May 2007 - 01:50 PM
Will try evey method you have come up with before I give up.....
cheers
Andy
#9
Posted 04 May 2007 - 10:04 PM
make sure the master cylinder entry point for the hose is the highest point in the hose route you may need to drop the caliper a little, turn your bars to the left as well. Pump the lever till you get some pressure in the system then zip tie the lever to the handlebar so it can t return.
leave it over night
in the morning it should work fine, if it does send a PM to Racey and say thanks as he told me and it worked when i did it.
still dont know why though......
#10
Posted 05 May 2007 - 04:35 AM
#11
Posted 05 May 2007 - 08:59 PM
Hopes this helps, Stoford.
#12
Posted 07 May 2007 - 12:35 PM
Sherco 50 Kid
Beta Rev50
Sherco 2.9
KTM 50SX
KTM 65SX
KTM 990 Adventure
Sydney
#13
Posted 07 May 2007 - 01:53 PM
#14
Posted 07 May 2007 - 02:37 PM
I did notice that when I assembled the swingarm and master cylinder back to the bike, the master cylinder connection that hold the pipe to the reservior rotated quite freely. I wasnt sure if this was like this in the first place?! I also noticed that when I had "finished" breaking my bike, that air bubbles came up into the reservior as I pumped the pedal. The cap was still off the res at this time.
To finish off my weekednd of destruction I snapped my gear lever on sun, at the very same rock i snapped my brake pedal last weekend!!!!!
Any advice on the brake would be helpful for me and hopefuly might help andy too.
#15
Posted 07 May 2007 - 09:01 PM
