BSA C15 Trials Project
#1
Posted 08 September 2011 - 06:34 PM
Was up the shed tonight and done a dry build on the rolling
chassis,seems like I will have to increase the ground clearance
as its quite low about 9",not very good.The frame is standard,
front forks are standard,What is the best length of rear shockers
to fit to help with the ground clearance.As I said its a long
term project as I'm enjoying riding my 250 Scorpa and learning
every trial I do.Any other advice would be much appreciated.
cheers the noo Brian
#2
Posted 12 September 2011 - 11:23 AM
We had the head angle altered slightly to tuck the wheel in which probably gave us a little extra ground clearance and the footrests dropped and moved back a little.
I think the rear shock length is now 360mm, but will need to check. With the mods i think the bike now has around 12-13" of clearance.
Before.
After. (have since replaced rear shocks)
#3
Posted 12 September 2011 - 09:26 PM
of the shocks you used please
Edited by broony, 13 September 2011 - 04:32 PM.
#4
Posted 13 September 2011 - 08:23 AM
#5
Posted 13 September 2011 - 10:02 AM
I have the ebay sellers name but wasn't sure if i could post it here?
#6
Posted 13 September 2011 - 10:27 AM
#7
Posted 13 September 2011 - 10:58 AM
#9
Posted 26 September 2011 - 06:55 PM
was wondering what width of rim to use?
#10
Posted 27 September 2011 - 07:28 AM
#11
Posted 27 September 2011 - 10:49 AM
If you need George Spence (the wheel builder)tel no just ask. He's at Cupar.
Ross
#12
Posted 08 October 2011 - 05:11 PM
trials project.
#13
Posted 09 October 2011 - 02:00 PM
#14
Posted 09 October 2011 - 07:08 PM
mcman56, on 09 October 2011 - 02:00 PM, said:
You can get the 18t engine sprocket here, see details re engine casing !
http://www.trialsbit...products_id=689
Incidentally I use 15 / 62 with 428 chain on the B40, some clever person will be able to work out if its the same as 13 / 72. But has the advantage of a slightly smaller rear sprocket for clearance.
Ross
#15
Posted 09 October 2011 - 08:24 PM
Ross
