steam
Mud
16 posts in this topic
Uphill and slippy muddy entrance to section. Tried starting off in 3rd with weight over back. Could not even get into section. Same if I sat down and padded. could not get initial  grip to start off.
Any advice appreciated.
Share this post
Link to post
Tyre pressure and condition?
Share this post
Link to post
Clear the rear tyre of mud just before you start the section.
1 person likes this
Share this post
Link to post
Rear suspension too firm/too much pre-load. Also if rebound is too quick traction problems occur. Many variables.
1 person likes this
Share this post
Link to post
3psi in the rear. Drop all your weight into the bike as you let the clutch out, so you're basically sitting on the airbox.
2 people like this
Share this post
Link to post
Agree with comments in addition are you giving it enough throttle at outset.
Share this post
Link to post
Will it pull 4th?can you get a bit of run up before the begins cards,momentum really helps when it's slippy.New rear tyre at 3.5 psi makes a big difference
Share this post
Link to post
I was , but I'm not gonna even comment , Tire pressure & throttle control .....
Share this post
Link to post
Depends on mud.
Different types, deep shallow grassy etc.
If you spin it in 4th it might work on deeper stuff.
second and very careful use of throttle can work ditto first, but from what im imagining you need to look around and see if there is a run up even small or grippy part to get going.
3 people like this
Share this post
Link to post
You are at the right end of the country to visit Steve Saunders for a 1 to1 Trials class, he is a master of muddy conditions and is situated near muddy bank trial land.....It will cost but would have a lot of value.
Make sure you pick the right time of the year to go when its raining sodden and slippery...Jan Feb Mar Apr May Jun Jul Aug Sept Oct Nov Dec are all months when the conditions should be at their worst.
Edited by oni nou
1 person likes this
Share this post
Link to post
https://youtu.be/jMl8hnkOI5U Study these world class riders and their technique well  and you should achieve as much as them in the grip stakes.
Edited by oni nou
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
