- Past hour
Excellent! Thank you konrad. OK, I can drive a suitable transistor with that to turn on the "spare" warning light on the OE dashboard. Am I correct to assume the 5V is relative to the ECU ground on PIN10? It seems almost as if the ECU manufacturer didn't finish the job, or tried to save a bit of cost by removing the internal MIL lamp driver. Thanks again. Cheers... Paul
From my notes... There is a symbol on the initial 2011 wiring diagram called "Testigo Averia". That translates as “Fault Witness”. I called it the CEL (Check Engine Light) in my notebook. Another name is the MIL (Malfunction Indicator Lamp). Looks like OSSA made it part of an instrument panel in the 2014 wiring diagram. Reverse engineered it a bit. It sources 5 volts at only 5 mA, so not too useful to drive a lamp. Even an LED is pretty dim. But, you could easily read it with a voltmeter. If your bike does not start, see if ECU pin 22 is at 5 volts (with the bike powered by a battery). This would indicate the ECU thinks there is a problem, versus the bike just being recalcitrant. Wiring diagrams are here: https://www.ossa-efi.com/home/electrics/wiring-diagrams
- Today
Cheers, typical of me to buy problems! 🙄
Thanks Alan. Really appreciate it
DWS started following New bike 250 or 300
Hi all, I’m asking for some advice please. I had a go at trials yesterday having been off bikes for nearly 20 years. I had a go on a 250 and did well on a yellow flag course. The guys said I would be good to have a go at a club trial. I enjoyed the 250 and found it very manageable. Looking for a bike now and can see a good deal on a 300. is there much difference between a 250 and 300? I worry if I buy a 250, I’ll want to upgrade to a 300 but at the same time, while I got on well, o don’t want to be cocky and buy a bike that might be too much for a beginner. any advice would be welcome. Thank you
tinwelp started following Explorer wiring...
Hello people, I'm tidying up a few wiring issues inherited from previous owners and I've hit an issue without an obvious solution. Can anyone tell me what the MIL wire from PIN22 on the ECU is supposed to do? It's currently connected in a very nonsensical way and I'd like to understand how it should be connected. Does anyone have specific knowledge? I've a loom with the six pin diagnostics connector and the easystart system if it helps. Failing that, does anyone know what happens to pin 22 in the cases of a fault and no fault? Thanks in advance. Cheers... Paul
Thanks seal in and looking good so far , I wonder if the seal is this way round because the garter spring in the seal is not made of stainless-steel and hence would suffer from corrosion and ultimately fail.
Yep, you have the most complicated and problematic carburetor design that was ever installed on a motorcycle so that they did not have to buy a fuel injection system from Honda. Most of the problems will be in the bottom half of the carburetor where the ethanol fuel evaporates out of the float bowl and leaves solids and corrodes parts, the top half won't be a problem until the rubber bits start to degrade and lose critical engine vacuum pressure. Avoid ethanol fuels if at all possible.
Millwoodva started following '98 TX270 Repair Manual
Just bought the bike a couple days ago and need direction and guidance for repairs. No luck searching Google. Happy to have found this Awesomely informative site! Thank you all in advance.
@Noel09 https://www.trialscentral.com/forums/topic/80228-fuel-tap-solenoide https://www.trialscentral.com/forums/topic/64519-beta-4t-fuel-tap-solenoid/
- 1 reply
- 1
@Noel09 www.betausa.com -support - trials - owners manuals = MIKUNI SE BSR 33-79 The information is all there. Regards Alan
Noel09 started following 2007 rev 4T 250 carb questions and Fueling inquiry on rev 4t 250 4 stroke 2007
Hi, sorry more questions. I'm trying to figure out my fuel system on the 2007 rev 4T 250 4-stroke. Mostly out of curiosity so if anyone knows them and could fill me in I'd be very thankful. OK in the manual the fuel tap has a weird looking fuel tap? My doesn't have the same. I'll add some photos. Mine also has a fuel outlet at the back of the tank with a weird nob on it? The fuel outlet on the side of the tank doesn't seem to have an on/off? The fuel lines go into a little chrome cylinder which I'm guessing is a pump? It plugs into the wiring loom. The block connector the feeds it has 2 extra wires that have been cut? It also has a hot start cable that runs into the bottom of the intake manifold but some cut the cable at the headstock? Do I need this? Thanks again everyone for help and advice. Noel
Hi everyone. I'm totally new to trials and just bought an old 2007 rev 4T 250 4-stroke. I'm fixing a few things and have a carb question. What carb is in my bike? I want to order a kit as the bowl gasket it weeping. The carb is a mikuni. There is some writing on one side. Looks like 33 79 L691? I did ask chatgp and it reckons it's a mikuni BSR33? But just want to make sure. Thanks Noel
For any person who has an interest . This gives some insight and interestingly from three riding levels which gives balance that is normally absent. https://youtu.be/3w_WxS411wY?si=ukWNMnZagaC 51:25 is the part of the video that specifically talks about marking regs. Regards Alan.
Tell of too much oil in your pre mix is how badly the exhaust plugs up with unburnt oil residue, naturally fuel rich condition intake also relates to oil rich. Your air cleaner filter needs to be clean and oiled correctly or that will starve the engine of air and lead to rich operation and poor performance, the reed valves need to seat perfect or scavenging pressure will force fuel and compression backwards through the intake so make sure the reeds seat perfect. Compression test is never a bad idea for diagnosis and future reference if you have the equipment. 👍
What octane fuel? If in doubt drop the main jet needle one notch and test ride it 👍
arden started following 2001 280 txt
HEY EVERYBODY RUNNING 80-1 AND PLUG IS WET ALMOST LIKE ITS RICH. IS THIS NORMAL?
arden joined the community
2004 gas gas 200 txt pro not sure if clutch is dot 4 or mineral
timmowatts replied to timmowatts's topic in Gas Gas
Thanks, I'll try the water test to make sure. Yes, know the brakes will be DOT It's just the clutch I wasn't sure about 👍 -
lemur replied to timmowatts's topic in Gas Gas
I suspect you are looking at DOT fluid; another test to try, mineral oil does not mix with water, DOT fluid mixes with water very easy. Only your clutch hydraulics would use mineral oil, brakes will always be DOT fluid. -
timmowatts started following 2004 gas gas 200 txt pro not sure if clutch is dot 4 or mineral
timmowatts posted a topic in Gas Gas
As title says, frame number suggests it's build is march 04. The master cylinder tops have been changed for aftermarket ones so can't go by the colour of the top. I had the Idea to take the top off and dab a cotton bud into fluid and rub it onto a painted surface (not on the bike 😉) and it took the paint off, so assuming I have DOT4 and not mineral oil unless that strips paint as well 🤔 Want to top up master cylinder and fit a repair kit. Cheers Tim -
timmowatts started following Hi and 2023 Sherco Long Ride with big bore kit fitted to 150cc
JennyH posted an advert in Petrol Trials Bikes
JennyH joined the community
Thought I'd been a member on here before, but obviously not 😂 Got a 2004 Gas Gas TXT 200 Pro
timmowatts joined the community
GasGas had the same forks at the time, so you could look at them also.
If you can actually find a seal and piston kit they are quite expensive usually , it may be better to pay the extra and buy a rear master made by AJP/BRAKTEC . Trials people refer to this as braketech for some reason but if you go to www.braketech.com you are not going to find what you want www.braktek.com is the real name of this company. Best wishes Alan.
I found their site earlier today and got sort it out .thanks
