Today
StuartG joined the community
Bassenthwaite and DMC D K Laing trophy trial
DK Laing trophy trial Round 1 of 2027 Northern Centre championship. All adult solo classes and youth A&B. Although this is multi lap trial it is still a good ride/distance round. Three courses Hard, Clubman and Green-50/50. 10.30am start flagged off A66 at Threlkeld with usual good parking in the Quarry/Mining museum. Postcode CA12 4TT Enter on the day only. IMPORTANT Strictly no practicing around the start area and no bikes to be started up before 10.30am due to being close to a residential area. Please can riders take a fuel can up to near section 1 to limit the number of bikes riding through the quarry. As always we are looking for observer's (with or without bikes) , if anyone fancies putting a bit back into our sport you will be fed and watered. Any help would be appreciated. ACU License required, day Licenses are NOT available. Stuart
Bultaco sherpa 250 1979
https://www.manualslib.com/manual/4138757/Bultaco-Sherpa-T-250.html?page=4#manual
https://static1.squarespace.com/static/5c2ec6bfb27e39b10aa5afc3/t/5fb4131017b8e34798c14e7c/1605636893706/Bultaco+Alpina+Manual.pdf
Bultaco 198A front wheel spacer
Hi, Does anyone have dimensions for the top hat bush (RHS). and, does the top hat bush fit inside the fork leg?
Hi Everyone, I have stripped down my bultaco while I get the frame powder coated, I started to re assemble today, the front wheel seems to rub bottom of the forks on the opposite side to the break lever, there is no clearance, I can't find an assembly drawing on line anywhere, there is the main centre spindle and 3 x bushes but the bushes look like an add on as only one of them is a nice snug fit, has anyone got any photos of the assembly? thanks in advance.
Mgu1 started following Bultaco sherpa 250 1979
Montesa Cota 200 (1981 ?) restauration
@ScottDownSouth Ok thanks mate I apreciate it ! I asked because I couldn't found any of it. Can't wait to start the engine. I'll let y'all know ! Cheers !
Hi mate, I found it on the internet somewhere..... Google is your friend. I think it was a link on a forum somewhere by memory. The manual is pretty basic. Just has basic specs and oil recommendations. Its certainly not a workshop manual by any degree. Cheers, Scott.
Yesterday
@ScottDownSouth thanks mate ! I appreciate it Do you know where can I find the manual you’re talking about?
Samdal joined the community
Sam 75
Im using 10w40 in the gearbox. The manual calls for 10w30 but I havent had any issues. Mixing the fuel with synthetic Castrol 2 stroke oil at 50:1. Spark plug is an NGK B6ES.
Last week
- Tire fabrication date
I’m sorry but I don’t know. It does say it’s for 1978 and onwards. Best of luck!
Fred1232 joined the community
First 2 digits is the # of the week, last 2 digits are the year abbreviated, same with all tires.
@ScottDownSouth Thanks for your help mate ! I'll definitely do that whenever I've got time. The second one is a Montesa Cota 75 (idk the exact year, probably in the late 70's). I love your bike, it's has be amazing to ride I guess ! Do you have any idea about it value on the market ? what oil lubricant are you using for the mix ? I'd thought about 10w40 or Motul 300v. And that about the oil lub for the gearbox ? Is there any type of spark plug I should use ? Thanks for your help !
Help identifying Engine and Frame numbers
My guess is you've got a Bitsa. B-68 Pursang MK4 250 Frame with a M-67 Sherpa S MK2 200 Engine. You could check the bore/stroke of the engine to confirm the capacity and hence the likely donor.
Hi mate, I have the same bike. Nice little Montesas! Yes I would flush the tank and put fresh fuel in it. Drain the fuel from the carby bowl. Check the Gearbox oil and sparkplug, see if it has spark. Check the condition of the air filter. They're usually good places to start. In Motion in the UK has quiet a few spares for these if needed. Pistons are rare though. What's the other Montesa in the background? Cheers, Scott.
@RonH Thanks mate ! Do you know of those are the same parts ? I'll take a look, I guess it's gonna help me a lot !
I hope this helps!
Hi there, I'm starting a Montesa Cota 200 restauration. My Grandfather bought it at the Montesa factory back in the time (first hand). She stayed maybe 30 years without starting. Could you help me with find the documentation I need (I speak Spanish so it might be easier to find one). I already have the parts plans in exploded view, but no technical documentation... I gently kicked it, and there’s no problem with the engine (I guess so, I could have kicked it entirely). It’s my first restauration and I have some very basic knowledge in mechanic, but it’s my first time in mechanic. The bike looks great, I don’t think there’s any rust on it. I’d like to remove the tank to clean it before filling it, what do you think about it ? I don't want to start it without checking the tank and his state (idk if you know what I mean, English isn't my first language). I'd like to check several parts before starting it. Also, there's the black part on the top of the shocks absorber (back) cracked, where can I find parts if they're still available ? Thanks for your help ! Ride safe ✌🏻
Xaarzuu started following Montesa Cota 200 (1981 ?) restauration
Xaarzuu joined the community
grahamdixon joined the community
DC_Dave joined the community
Purswang joined the community
Hey all, looking for some help to ID my engine and frame numbers. Some lists I found online have been conflicting so wanted to check here for clarification. Frame is B-68 and Engine is M-67 Any help much appreciated!
Beta Sincro leaking gas
I had an issue on an Evo where if the bike tipped over, the overflow hose would fill with fuel and siphon fuel out of the bowl. I cut a small notch in the line close to the carb and that stopped it.
Irc tyres
New tyre is tubeless and heavier.
Irc tyres
Hi, the older tube tyre dated 5212, trialed on a bantam and run both directions. New tyre is up to date. Thanks
Little question about dimple plates
If that is what a Montesa specialist sells then you are in a bad way , APICO sell a dimpled set of steels but then those perhaps are a set from APICO , who knows .
