Report Gas Gas VIN in Gas Gas Posted May 1, 2019 That's nothing like a gas gas trials vin. should look like pic
Report Oil Filler in Gas Gas Posted April 16, 2019 · Edited April 25, 2019 by Bilko That's a 2004 sorry 1994 be away a week not checked here plus yellow plastics denote 125 or 200
Report evo fork seals in Beta Posted April 13, 2019 · Edited April 13, 2019 by Bilko Might help https://www.betausa.com/sites/default/files/pdf/2016Evo3002towners manual.pdf
Report jay rasco in Gas Gas Posted April 5, 2019 · Edited April 5, 2019 by Bilko VTREC indicates it's a enduro model VTRGG indicates a trials model If you find model/ Manuals and parts diagram here.https://gasgas.com/en/manuals?c=enduroandy=
Report SHERCO 2004 FUEL TANK in Sherco Posted April 3, 2019 · Edited April 3, 2019 by Bilko Used to be common problem petrol tanks leaks from the tap where it mounts to the tank.Try ringing Splatshop for advice
Report Hole in Crank Case in Gas Gas Posted April 1, 2019 · Edited April 1, 2019 by Bilko No that shouldn't be like that,part of the case is busted,but there should be a plug or bolt of some kind where your hole is.
Report Having problems after replacing woodruff key in Gas Gas Posted March 26, 2019 · Edited March 26, 2019 by Bilko Did you mark it before removal,if you removed it cos that looks like it's on fully retarded,which will fire after .Try central position then move either way if it runs. 1
Report Log book and engine nos dont match in Sherco Posted March 25, 2019 Simple take t back not as described Sherco should know if the reg or vin is a Factory. Edition http://www.BLOCKED LINK.com/2015-sherco-factory-trial/
Report 2010 Beta Evo Flywheel Puller in Beta Posted March 25, 2019 Yes same as Rev 3 according to this https://www.ebay.co.uk/itm/New-RFX-External-RH-M30xP1-5-Beta-Rev3-Evo-00-16-Sherco-Scorpa-Fly-Wheel-Puller/173001997503?hash=item2847b8fcbf:g:-90AAOSwVtZaHDJH
Report Spares and accessories at a trial in General Trials Talk Posted March 14, 2019 Also some of these if you run tubeless rear tyre https://www.ebay.co.uk/itm/Tubeless-Tire-Repair-Tool-10pc-DIY-Flat-Car-Motorcycle-Home-Plug-Seal-Patch-Box/401727204580?hash=item5d88ceace4:g:2P0AAOSw6JZchqyu
Report Dugzy in Trials Gear Posted March 9, 2019 Google is your friend https://www.jsaccessories.co.uk/stores/braintree 1
Report Newby in Introduce Yourself Posted March 4, 2019 Yes just the small center bolt in the clutch hub .you can get a handbook and parts diagram here https://gasgas.com/en/manuals
Report Newby in Introduce Yourself Posted March 4, 2019 · Edited March 4, 2019 by Bilko Kickstart gear and intermediate idle gear prone to chip.which is approx £150 for the pair. video how to replace if needed,
Report Over heating issues with my 1998 txt 250 in Gas Gas Posted February 28, 2019 96/2000 Wiring diagram.
Report 2010 Evo 250 - wear to coating on stanchions in Beta Posted February 20, 2019 I have a 2007 SY 250 with the bottom cpl inches of coating worn but they don't leak.But you could get them re coated if needed.
Report Rev 3 plastics in Beta Posted February 9, 2019 · Edited February 9, 2019 by Bilko New https://trialstribulations.net/index.php?main_page=product_infoandcPath=33andproducts_id=1280andzenid=hncv4kp58c5p4f52ecvhkvu4n1
Report Rev 3 plastics in Beta Posted February 8, 2019 No after market mudguards,Evo won't fit and depends what yr your after also 2000/3 no air filter cover. Removable Air filter cover on 2004/8
Gas Gas VIN
in Gas Gas
