This issue continues. I was deflating and reinflating tube to get it centered every couple of rides. I also increased pressure to 5 psi. In other bikes I use 4 psi. I stopped the deflation/ inflation step and developed a leak at the valve stem in a maybe 5 short rides. I installed a 4:25/ 4:50 tube and ripped the stem off in only a few miles of dirt with no rocks. There was no impact. I just came around a turn on a flat road, gave it a good bit of throttle and could feel it go flat all at once. The tire remained seated on the rim. I rode the bike about 1/4 mile with the flat and the tire was still firmly seated on the rim. The bike has a DID 2.15 x 18 rim. This is really odd. I'm not sure if I should try an IRC tire or maybe the tubliss system. Does anyone run Tubliss on a trials bike?
I run an FMF universal muffler on a TY175 and it really quieted the bike down. On that bike, I was able to just cut off the OEM muffler and clamp the new muffler on. I used the smaller FMF universal but did need a reducing collar to fit the TY. I can't picture how thick a the TY mono muffler is but the FMF is a bit wider than modern trials mufflers so you have to make sure you have clearance. Beta 4t (at least some years) had no external stinger to clamp on so the spainsh fly spark arrestor came with a short piece of tubing you had to weld on the back of the muffler to accept the spark arrestor.
These types come in different sizes. They have the correct screen size but I don't think they have the official words. They do pass inspection at the CA off road parks I go to.
The O5 in a circle sounds like a casting date. Things like this would be cast in large lot sizes. Then there is machining and painting plus transit times. I have spent a little time looking at casting dates on Beta cylinders. A cylinder with 05 casting date would likely be found on a 2006 or even a 2007.
I was able to reduce shock through the handlebars on my TY175 by using a fat bar and rubber mounts from a mid 2000 CRF250. See picture. I was already using risers to put the bars in that position so there was no ergonomic change. At rest, I can flex the bars a bit but notice no negatives while riding. Rox Risers sell something that looks similar. I don't see a good way to squeeze these into a modern bike without a big change in bar position but have found it is quite easy to change the valving in a modern Beta's forks.
Can someone clarify how to install the front sprocket retention hardware for a TL250?. There is a flat washer with cut outs to slide on the spline. There is a second washer with similar cutouts which also has some horizontal protrusions that will mate with the first washer. However, I don't see how these two washers can mate once on the spline. Then there is an e ring that fits but is not a tight fit in the groove on the spline.
I did notice that quite a few 15 mm spacers are sold for car wheels. Could any of them be small enough to modify? You could probably use something much less robust than what I did. IIRC the TL250 sprocket mounting studs are 10 mm. Modern trials bikes use 6 mm.
The drawing is not to GD&T standards but implies a circular hole pattern with a 1.771" radius and holes every 90 degrees to match the stud locations....if that makes sense. You could probably make a simpler spacer but I tend to over design. The sprocket got thin at the groove area and I wanted to support it well. If the groove was faced away from the hub, a simple flat spacer would work but you would need washers or something similar in that groove. I'm really curious what the groove is for on the 125. Could Honda sell some kind of lock washer part that fits in there?
I got the chain and sprocket kit from TY Trials. Pricing was quite good but for some reason was shipped 2 day to the US which almost doubled the price. TR216 60 428 was the rear. TG314 12T (428) was the front. From what I can tell the front was a special order because that P/N is normally a 520 chain. They show a spacer as unavailable on their web site. Speed and Sport in the US also showed a spacer listed as unavailable.
If I were to do it again, I would consider a 520 chain. I saw at least one sprocket company on line that still sells 12T sprockets for the 1976 XL250. They could probably supply a rear sprocket with the correct number of teeth that would be flat so the groove would not have to be considered. I'm guessing they do spacers also.
I made one out of aluminium. The sprocket was a Talon supposedly for a TL125. It was not totally flat so had sort of a groove on one side. I'm really curious what that groove is for on the 125. A drawing is attached. I did add a 45 degree chamfer on the hub side.
A custom sprocket company may also be able to help.
I used something similar on a DT175 with 12 volts. It came without any kind of regulator and would blow up bulbs. This basic type regulator cured that issue. We had some kind of variable AC voltage generator at work so I hooked it up to see how it worked. It did nothing until about 13.5 volts and then interacted to hold the voltage down. I guess the diode "opened" at 13.5 volts and sent excess power to the resistor that dissipated it as heat.
If I am following this correctly, the diode plus resistor you mention make what is a basic voltage regulator as used on various small motorcycles. Its purpose is to limit voltage to the lights so they do not fail. Something like this:
I bought a new chain and sprocket kit for for my TL250 but no spacer was available for the rear sprocket. I can make one but am seeing only two ways, neither of which is highly desirable. See picture 1.
-If I mount spacer to hub and then sprocket to spacer, I will have to open up holes in the freshly anodized sprocket for nut clearance for the spacer to hub attachment.
-IF I could find longer studs, I could use them and basically sandwich a spacer between sprocket and hub. However, I suspect that studs that have been in place for 1/2 century will not come out easily.
What have others done? Pictures? The sprocket is supposed to be a TL125 sprocket but has an undercut on the back side. Does anyone know what that is for?
I don't remember the Techno but there was a CDI/ coil combo replacement for the 2008 Rev3. I bought one as a spare and still have it but have no idea if it would work on a techno. The 2008 Beta came with separate CDI and coil.
I'm not sure if this helps but I had a Techno and it was likely a 1997. I once put a timing light on it and got 6 degrees at idle, 20 at mid range and 25 to 30 at full scream. If the CDI advance stuck at full advance it may kick back.
In contrast a 2008 Rev3 200 had 15 degrees BTDC at idle and revved up got 20 degrees I'm not an EE but from my understanding, an ignition with no designed in advance will give you about 5 degrees due to higher generated voltages at higher RPMs making things happen a little quicker.
Not really answering your question but I aren't all coils for CDIs similar? Could you use a pit bike coil? IIRC, there are inductive (battery powered) and capacitive discharge ignition coils and they have different resistance values. You could measure to compare.
Is there any kind of manual related to servicing the shock on a 2016 Evo 4t standard model? If not, are there any specifications for oil type, oil volume and gas pressure? I do see the remains of a sticker that probably said Sachs.
I softened the fork valving and like the result so would like to soften the shock also.
A friend has a 22 Epure and the battery status is stuck at 0%. The bike works and appears to charge OK. Is there a way to reset or calibrate? Does anyone know how this works? Is it a simple voltage measurement used to estimate % charge?
It turns out I was trying to push the rod out from the wrong location so it was not really stuck. I cleaned and polished the sliding parts. Steel plates were glass beaded and the friction plates replaced with Yamaha parts. Swapping spring locations while checking with an indicator got the plate to move out evenly within .05 mm. Clutch works great now. I suspect it was really the new friction plates that helped the most. I did polish the actuator but have never looked at another old one for comparison. I suspect that all 45 year old actuators look less than perfect.
My 2014 Factory model came with those. The parts list shows them in positions 2 & 4 of 6. There was something else different about the clutch too, maybe the hub. I could never figure out what the additional features were supposed to do. The clutch did not work any better or any worse than any other Beta clutch.
Tube Rotating in Tire?
in Twinshock
Posted · Edited by mcman56
add detail
