Would depend where you are I guess. I have found these simple ignitions are not too fussy about the actual capacitance of the condensor as most are similar values. Try to find one that can be fiited easily for a start.
The original Ground would of been a green wire if I recall correctly and would of started at the grounded ends of the stator coils and via the connector block terminated at the coil mounting bracket.
LT was Black I think! and was connected to the points and the other end of the LT Stator coil.
To make the ignition work you only need a Good Ground and the LT wire connected.
I'll find a condenser today. Can anyone tell me if the under tank condenser is stock? There is a mounting space for it under the flywheel as well.
It's a common mod. Makes life easier when changing them and also will be in a cooler enviroment. You only need the one wire coming up from the stator to coil and a ground.
I would recommend you change the condensor and put fresh crank seals in it even if just to remove those from the equation. Both are simple parts likely to cause much frustration for no known reason!
On Bults laid up for a while I have also seen sticky points pivots cause severe frustration!
I'm sure they have, but I did say "but usually left the factory" with the single plug hole. Out of many heads I have in my parts store only a few 9:1 Sherpa heads have 2 x 14mm threaded holes, and most likely they were drilled and tapped out for compression releases.
I do however have a twin spark 370 Pursang in my Bultaco collection and it is really that, ie twin spark. The motoplat coil has two ht leads and both plugs spark simultaneously.
Until we know the OP's model number we will never know what he has.
Both my Sherpas have twin plug heads, which work great for compression releases.
Dave
Most if not all Bultaco Heads have the bosses for the extra plugs or comp releases, but usually left the factory with just the vertical central plug boss machined on Sherpa's. The twin spark Pursangs etc usually used the alternative angled bosses, both plugs at about 60 degrees.
In Addition to the suggestion above, if the bolt is now useless it does help to drill a hole into the bolt concentrically just smaller than it's outside diameter but not right through. Effectively turning the bolt into a blind thin wall tube.
It will then tend to collapse and free off much easier.
Preferably use a hot air gun to do the heating on Mag Alloy.
Did you ever sort this out? Noticed you never had a reply!
I just stripped a pair myself, You need to warm the top of the slider and unscrew the seal carrier/top bush.
I had a battle with mine but not in that area, mine have to come completely apart for rechroming and the bottom of the tubes has a steel wear strip carrier screwed into them and it was a bitch to remove as Telesco in their wisdom deliberately disrupt the thread though a hole in the tube, Loctite would of sufficed!
Take a good look at the condition of the roll pins holding the "damper rod" assy together, they can shear with exciting results! Damper rod my AR&%!! Did they really have damping qualities? Hard to imagine!
I have fitted a standard airbox to my bike now but can't find anywhere to buy a filter from. I made my own filter using foam from a spare petrol disc cutter filter I had.
The problem is the bike runs really rich especially at the lower throttle openings (up to 1/2 or 3/4). Dropping the needle helped a little but still way out. With no filter on the bike runs clean.
Either my home made filter is too restrictive or someone has re jetted the carb to run without one.
Steve
I think the 242 one is basically the same. Dave Renham has them at InMotion it appears.
I'm not sure where I put the original from my airbox when I cleaned the box out. But it's here somewhere!
Not so sure it's criticism really. But there is a certain amount of irony considering the Centrally Speaking post this week.
I have been more interested to see how my pals have gotten on personally, and thanks to the Todotrial site I'm more aware. Next year maybe we'll make the Pilgrimage
Almost like the KLG plug in my 1925 Triumph Funny how these things have a 2nd or 3rd life. Admittedly the vintage plugs didn't have the electrodes joined.
Thats good Alan. Is it stable now? How much effect did the Ferrite have? Did Maplins have one? or did you get it elsewhere?
One would ASSume that if the other device you talked about is designed for motorcycle use then they have designed it with at least some RFI precautions.
thinking aftermarket accessories here Wayne........
Nah, but I did a few years ago make alloy bodies for these speedos to be used on road bikes There was a weird chain of events leading up to that work, all because a lost German biker got chatting to me at traffic lights while I was riding my Morini 500.
But I digress... A lot of RFI issues can be reduced with good earth bonding techniques, I see issues like these on my cnc machines when bonding issues rarely arise.
Your problem is almost certainly RF noise coming from your ignition. The signal levels in the bicycle speedo are low and the RF is swamping the signals from the wheel sensor and probably being picked up in the cable from sensor to readout.
As they are two separate circuits you also have a floating ground in the speedo, so another option to try and may be the simplest is to somehow ensure the Battery Negative in the speedo is bonded to your frame assuming you are Negative Earth, which using PVL? I would of thought so. This will either work, Not work or rare chance it fries the speedo depending on how well it's designed.
Sherpa T Mystery
in Bultaco
Wayne....
