Spare Rear Wheels
ive got an 04 mont and an early spare wheel that does not fit, i also have an 04 and 05 sherco .ill try the swap!
  • Replies 41
  • Views 11.6k
This is the part #42610-nn. on the sales receipt, I will also count the spokes!
didn't Mont change the number of spokes in the rear wheel a few years back, will be back with more info.................. it's a 36spoke rear and I used the spacers that came with the Mont wheel, not the sherco spacers.
The most critical part is making sure the disc is centered in the caliper.
Looking at the hub I think the do it youselfer could lace whatever hub`they wanted to the DID rim useing the mont spokes.
Edited by ishy
nigel how cum the other day i took a sherco 04 wheel out&put it strait into my 04 gas gas?the wheel fit perfectly the spacers are exactly the same?i dont think you no as much as you think you know!young man!!!!!
Perhaps you are right about 04 04 swap, but when I compared an 04 sherco (290) to my mates gg (pro) 03 it was not the same. Are you still saying the 02/03 are the same as the 04, or did I miss something????
I was trying to help the topic thread starter not get in an argument with you knumbnuts. :rolleyes:
thanks ishy you could have saved me a job :rolleyes
early mont wheel does not fit so its post 2001
take your wise craks&go play with your flat slide carb num nuts
Well said. Got to be looking at around
no dabster u have got it wrong!when you buy a spare wheel it doesnt actually come with anyspacers in!so u could go to rathmalls buy a spare wheel for
