benwall Posted August 23, 2010 Share Posted August 23, 2010 When im riding i can suffer from back pain, some companies claim that there rissers can stop back pain when riding, can anyone tell me if bar rissers are any good and if they have helped them? Quote Link to comment Share on other sites More sharing options...
2fargone Posted August 23, 2010 Share Posted August 23, 2010 Doubt it ...but a Thai massage can. Quote Link to comment Share on other sites More sharing options...
daithi Posted August 23, 2010 Share Posted August 23, 2010 I'm 6'2" and I've got 40mm Risers on a GasGas 250 and they help a lot. Keeping your knees bent takes a lot of the pressure off your back too, even if you only do it every few minutes. Quote Link to comment Share on other sites More sharing options...
jes42 Posted August 29, 2010 Share Posted August 29, 2010 What type of risers are you using ? 40 mm sounds a lot. I'm looking for some for my scorpa and believe I need the same as the ones for the gas gas. Any ideas ? Cheers. Quote Link to comment Share on other sites More sharing options...
benwall Posted August 30, 2010 Author Share Posted August 30, 2010 Just thought surley the bar risers afect the handeling of your bike Quote Link to comment Share on other sites More sharing options...
nzralphy Posted August 30, 2010 Share Posted August 30, 2010 20mm higher bars for me and I'm 6'2". Brilliant. Get em. Quote Link to comment Share on other sites More sharing options...
billycraig Posted August 30, 2010 Share Posted August 30, 2010 When im riding i can suffer from back pain, some companies claim that there rissers can stop back pain when riding, can anyone tell me if bar rissers are any good and if they have helped them? If the pain is caused by flexing the spine then adding the risers should take you into a little more extension and reduce the pain. If its due to a weakness in the surrounding musculoskeletal structure then I'd say it will come back eventually even with the new riding position. I'd try using the risers to solve the problem in the short term but also try working on some back stretches and also some lower abdominal strengthening. Quote Link to comment Share on other sites More sharing options...
benwall Posted August 31, 2010 Author Share Posted August 31, 2010 what size bar risers should i use as im 6ft and i have rather long arms Quote Link to comment Share on other sites More sharing options...
fred_savage Posted September 3, 2010 Share Posted September 3, 2010 I'm 6'.5" tall and suffer from back trouble now and again, often after a long drive or time at desk. When it Quote Link to comment Share on other sites More sharing options...
motojojo Posted September 4, 2010 Share Posted September 4, 2010 Core exercises, bar risers, lower pegs,move them back and row the bars forward are all good but the first 1 is most important. Work the core. Quote Link to comment Share on other sites More sharing options...
billycraig Posted September 4, 2010 Share Posted September 4, 2010 Core exercises, bar risers, lower pegs,move them back and row the bars forward are all good but the first 1 is most important. Work the core. And before that, remove any inflammatory foods that are stopping the core muscles doing what they're supposed to do. Number 1 cause of back pain, poor diet switches the muscles off as the various organs share the same nerve network as the surrounding muscles meaning the back gets overworked when the abdominals don't do their share of the work. Quote Link to comment Share on other sites More sharing options...
b40rt Posted September 4, 2010 Share Posted September 4, 2010 And before that, remove any inflammatory foods that are stopping the core muscles doing what they're supposed to do. Can you give some examples ? Quote Link to comment Share on other sites More sharing options...
daithi Posted September 5, 2010 Share Posted September 5, 2010 What type of risers are you using ? 40 mm sounds a lot. I'm looking for some for my scorpa and believe I need the same as the ones for the gas gas. Any ideas ? Cheers. I milled mine from aluminum bar, 40mm is perfect and effects handling in a positive way, it gives more room on the bike with little or no change to weight distribution. Takes all the strain off the lower back and puts the bars more in front of you. 2cents Quote Link to comment Share on other sites More sharing options...
jes42 Posted September 9, 2010 Share Posted September 9, 2010 You mean you raised the bars by 40mm? Sounds a lot but if it works.... What year is your scorpa? I have an 09 and am looking to raise the bars but so far I can only find the S3 risers and think they are a bit pricey, also paying for fore/aft adjustment which I'm not sure is necessary....Any thoughts or advice more than helpful...Thanks Quote Link to comment Share on other sites More sharing options...
