jeeves88 Posted January 28, 2012 Share Posted January 28, 2012 Mig welding on bike, what about the electrics of the bike? 11 sherco? Quote Link to comment Share on other sites More sharing options...
fivebunny Posted January 28, 2012 Share Posted January 28, 2012 Your not supposed to as it could damage the electrics.Dropping the engine out and disconnecting the electrics cant take the long just for piece of mind. Better taking an hour longer than having to fork out brass for something you could have prevented! Quote Link to comment Share on other sites More sharing options...
digger144 Posted January 28, 2012 Share Posted January 28, 2012 make sure earth wires are disconnected ,a bad earth on welder connection could put unwanted power throughbike wiring, play safe & disconnect everthing Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted January 28, 2012 Share Posted January 28, 2012 make sure earth wires are disconnected ,a bad earth on welder connection could put unwanted power throughbike wiring, play safe & disconnect everthing And make sure your earth lead is as close to the weld as possible. Quote Link to comment Share on other sites More sharing options...
reggie Posted January 28, 2012 Share Posted January 28, 2012 Bond all wires together after diconnecting them.Better yet take ignition and all electrics off of the bike. Quote Link to comment Share on other sites More sharing options...
woody Posted January 28, 2012 Share Posted January 28, 2012 On the flip side, I've known people MIG snd TIG weld bikes with electrics still connected with no adverse affect. I wouldn't do it though and always disconnect the wires for peace of mind (although I haven't a clue what's actually happening in terms of current etc. - don't understand electricity....) Quote Link to comment Share on other sites More sharing options...
copemech Posted January 29, 2012 Share Posted January 29, 2012 Wonder what part you are welding on an '11? Me, I would probably disconnect the magneto harness and possibly remove the cdi unit. Insure a good ground close by. Quote Link to comment Share on other sites More sharing options...
jeeves88 Posted January 29, 2012 Author Share Posted January 29, 2012 Now then, Thanks very much figured that might be the case like, but without a battery i didnt think it would take much harm. Cheers Quote Link to comment Share on other sites More sharing options...
renov8 Posted December 3, 2012 Share Posted December 3, 2012 Having been a welder for 28 years I would recommend disconnecting all wires coming from magneto, generator and battery. Do make sure the wiring is totally isolated. Remove fuel tank and plug pipe to carb. Remember when welding sparks can travel so keep surrounding area clear, dampen floor with water, and if possible get someone to stay nearby. Take care cleaning the area to be welded, and don't rush. Good luck. Quote Link to comment Share on other sites More sharing options...
tankygsy Posted December 4, 2012 Share Posted December 4, 2012 As an engineer I wouldn't reccomend using a mig to weld anything on a trial bike unless it was aluminum and you are a good welder. If its steel or 4130 CoMo and you care about your bike it should be tigged or oxy/accetelene welded. 4130 also needs a specific filler rod suitable for super steels. Dont get me wrong You will get away with a mig welder and regular steel welding wire but it won't be as strong as the parent metal or look abywhere near as neat as it could so you might be welding it again in the near future when it starts to crack. It'll be okay for a quick repair, just not the best. Quote Link to comment Share on other sites More sharing options...
tankygsy Posted December 4, 2012 Share Posted December 4, 2012 Just realized this thread was started way back in January! Hope your weld is holding ??? Quote Link to comment Share on other sites More sharing options...
