westygas270 Posted February 26, 2012 Report Share Posted February 26, 2012 Hi has anyone had similar problem with there bike? mine is a 2010 290 evo been out on it today and it has started making a v loud whining noise grinding noise, not sure if from piston area or clutch to have a look? sounds like it is piston but surley not on a 2010 bike ? help pls Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted February 26, 2012 Report Share Posted February 26, 2012 Hi has anyone had similar problem with there bike? mine is a 2010 290 evo been out on it today and it has started making a v loud whining noise grinding noise, not sure if from piston area or clutch to have a look? sounds like it is piston but surley not on a 2010 bike ? help pls check flywheel weight first Quote Link to comment Share on other sites More sharing options...
westygas270 Posted February 26, 2012 Author Report Share Posted February 26, 2012 seems ok m8 Quote Link to comment Share on other sites More sharing options...
pindie Posted February 26, 2012 Report Share Posted February 26, 2012 Sounding like time for a strip down? Quote Link to comment Share on other sites More sharing options...
westygas270 Posted February 26, 2012 Author Report Share Posted February 26, 2012 its looking that way its loud not a small noise, has anyone had problem with clutches on them? Bikes hardly had any use but i got told that the material on clutch goes and they can do it? sounds more than that to me tho Quote Link to comment Share on other sites More sharing options...
betabonkers Posted February 26, 2012 Report Share Posted February 26, 2012 I had piston slap on my 2010 when it was 6 months old. Quote Link to comment Share on other sites More sharing options...
westygas270 Posted February 26, 2012 Author Report Share Posted February 26, 2012 more than piston slap m8 tho screaming out when running Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted February 26, 2012 Report Share Posted February 26, 2012 best get someone with some idea to have a listen ,or remove clutch cover and have a look Quote Link to comment Share on other sites More sharing options...
westygas270 Posted February 29, 2012 Author Report Share Posted February 29, 2012 just on with strip down atm and looks like the big end has gone bout 7 month old bike Quote Link to comment Share on other sites More sharing options...
pindie Posted March 1, 2012 Report Share Posted March 1, 2012 What oil mix are you running? Do you do road work? Lots of full throttle work? For this to happen something is not right. Most likely a lack of lube or duff bearings from new? I don't know what your carb settings should be but I'd check them out to make sure enough fuel mix is going through the motor to lube it. Quote Link to comment Share on other sites More sharing options...
westygas270 Posted March 2, 2012 Author Report Share Posted March 2, 2012 carnt remember what ratio it is i use without looking have it marked out have used it on my betas b4 and run spot on to now, nope no road work or full throttle hardly need it from torque of the bike think its duff bearings got to see lampkins in the week to talk to them bout it Quote Link to comment Share on other sites More sharing options...
nelly1 Posted October 30, 2012 Report Share Posted October 30, 2012 what happened with it mate Quote Link to comment Share on other sites More sharing options...
jfc Posted December 10, 2012 Report Share Posted December 10, 2012 Any update? Quote Link to comment Share on other sites More sharing options...
nelly1 Posted December 11, 2012 Report Share Posted December 11, 2012 the suspense is killing me its like who shot jr Quote Link to comment Share on other sites More sharing options...
liviob Posted December 12, 2012 Report Share Posted December 12, 2012 Knock knock! Who's there? Worn bearings & piston! Worn bearings & piston who? Beta! Beta? Yeah, you Beta replace my worn bearings & piston before bigger problems occur! Quote Link to comment Share on other sites More sharing options...
