herman Posted May 9, 2012 Share Posted May 9, 2012 Just finished my project TL270 and I must say I am more than thrilled with the result.... I ended up using a 270 cc piston kit, a heavier xl250 flywheel, and a cut steering head (1.5 degrees). The shakedown ride went quite well - I've never enjoyed a trials bike more in my 35 years of riding. The bike was pure joy.... and then, and you knew this was coming, she signed off with a misfire. Back at the ranch I started the investigation. The bike kicked over with good compression, but had no spark on what I would call a plug that had a good tan color to the ceramic part, yet had black carbon ash on the edge of the threads. Plug was new before hand. The points looked a bit burnt as well, so I ordered a new set and a used coil / condensor to try in case it was needed. The old points got so hot that the fibre plastic type washer on the points body was melted. Indeed the bike ran hot... OK, so with the new points / new coil and even the old coil - no spark........ I used the old plug after giving it a good cleaning. Am i missing something else that may have failed due to excessive heat? Other info: When assembling the motor I powder coated the cylinder and head. The ignition plate was adjusted about a quarter inch counter clockwise. As the motor spins that direction, I assume this is retarding the ignition. If I can get spark I'll readjust this closer to normal. I figured the bike would run a little hotter during break in, but it appears I've gone more than a little hot. I've considered running a colder plug in additon to the ignition adjustment. My air seal on the intake is good, so no worries there. Any advice? Quote Link to comment Share on other sites More sharing options...
motovintage Posted May 9, 2012 Share Posted May 9, 2012 source coil? Quote Link to comment Share on other sites More sharing options...
craig10 Posted May 9, 2012 Share Posted May 9, 2012 (edited) I don't know these engines, only the tl125 series but if it's points ignition with a battery and not CDI, check with a meter that the points are definitely making and breaking and that you've got voltage at the coil . If you touch the points wire to earth and then break the connection with battery power on the coil you should get a spark at the plug, making sure of course that the plug body is well earthed. That way you should be able to isolate it to the points or coil. Could be that. the isolating washers are incorrectly assembled at the points wire connection. Edited May 9, 2012 by craig10 Quote Link to comment Share on other sites More sharing options...
stork955 Posted May 9, 2012 Share Posted May 9, 2012 Gday, if the points have melted you have the wrong type of coil on the bike. You need one for a standard magneto, you have probably fitted one designed for CDI which has a lower primary resistance. Also, fit a new condenser as they can sometimes cause burning on the contact faces. Check the source coil resistance as Christopher mentioned above and there is nothing else to do. Leave the plug, it sounds perfect, as does your carb settings. You always take notice of the ceramic, the rest has no bearing on the plug reading. Hope this helps, Cheers, Stork Quote Link to comment Share on other sites More sharing options...
bigmike1961 Posted July 7, 2012 Share Posted July 7, 2012 Any updates? Solutions? Quote Link to comment Share on other sites More sharing options...
ross brown Posted July 10, 2012 Share Posted July 10, 2012 "Just finished my project TL270 and I must say I am more than thrilled with the result." Photos please. Quote Link to comment Share on other sites More sharing options...
bashplate Posted July 10, 2012 Share Posted July 10, 2012 "Just finished my project TL270 and I must say I am more than thrilled with the result." Photos please. yup.....pictures please Quote Link to comment Share on other sites More sharing options...
maxbikes Posted February 2, 2013 Share Posted February 2, 2013 these engine run hot at best of times,so powder coating head and barrel it will get even hotter,you will also need oil cooler,and best oil you can find changing oil every time you use it. Quote Link to comment Share on other sites More sharing options...
gregr Posted March 13, 2013 Share Posted March 13, 2013 Totally agree with Maxbikes , never powdercoat any parts that need air to cool them, the powder coating traps the heat and you will cook the item .... you now have the un-enviable problem of getting the coating off the fins. Quote Link to comment Share on other sites More sharing options...
buzz white Posted August 29, 2015 Share Posted August 29, 2015 Guessing this is Old But Here Goes anyway. I Have a Honda TL 250 and would like to know if i can fit a XL 350 Crankshaft and barrel/Piston to my Crank case Hello am new Here but looks great Buzz in the UK Quote Link to comment Share on other sites More sharing options...
hendrik Posted August 29, 2015 Share Posted August 29, 2015 (edited) I had a fraser with 380cc, Xl350 cranc and big bore piston, made by a dutch mechanic.... http://www.trialscentral.com/forums/topic/52663-some-fraser-tl-questions/#entry396041 Edited August 29, 2015 by hendrik Quote Link to comment Share on other sites More sharing options...
buzz white Posted September 1, 2015 Share Posted September 1, 2015 Thanks its a Good Start, Just a Standard XL 350 would be ok for me. Parts Required (I am Guessing) XL 350 Crankshaft. XL350 Barrel(Jug) & Piston, XL Cylinder Head ? My TL250 Crankcase Any Answers would Love to Know. Dave. Quote Link to comment Share on other sites More sharing options...
bashplate Posted September 2, 2015 Share Posted September 2, 2015 might be a daft question....but why not just put complete 350 motor in there? Quote Link to comment Share on other sites More sharing options...
buzz white Posted September 3, 2015 Share Posted September 3, 2015 Would do That,but Correct me if i am wrong but the Gearing in the Gearbox are different on the TL 250 Quote Link to comment Share on other sites More sharing options...
hendrik Posted September 4, 2015 Share Posted September 4, 2015 The TL250 gearbox is different, but fits in a 350 engine... 1 Quote Link to comment Share on other sites More sharing options...
