June 12, 201214 yr My 280i SSDT model has a problem with the electrical system somewhere. It cuts out in stages when it is hot.... First the top and mid end goes and then after limping around on low revs for about 2 minutes the engine cuts completely. It is impossible to start until it has cooled for maybe 5 minutes and then it starts as normal on the first or second kick. Subsequent to that it runs normally on either map until it has heated up.....the same sequence after a shorter time. I feel it is in the left hand engine case as it started after a shorter interval after I poured half a bottle of water over it. The problem happens after exactly the same interval after starting riding and I have tried a new plug to no avail (even though the old plug was a perfect milk chocolate colour). Please offer any suggestions as the opinions I have canvassed so far all suggest a coil or stator about to fail.....
June 12, 201214 yr hi, its more than likely the stator or cdi breaking down i would remove them along with coil and send to a motorcycle electrics repair shop unless you can get hold of someones to try on youre bike
June 12, 201214 yr Hi there, I had a Beta Techno several years back that had identical symptoms as that and it turned out to be a faulty stator,it would run for a period of time and then give you the symptoms of a plug breaking down. My Beta would always end up with water being held in the ignition cover as it was very pliable plastic ignition cover that seemed impossible to seal. And on that note,my 2012 Ossa has also been taking in water to the ignition side,I removed the cover yesterday to find bad rust marks on the flywheel due to water laying in there for sometime,so all you guys need to check this now and again,I will be trying to see if I can improve the seal will a smear of silocone. I have just ordered a flywheel puller to remove the flywheel on mine and give everything a good clean,by the way the flywheel puller is the same as a (Gas Gas Pro) M27mm x 1mm (right hand thread). Hope this helps.
June 12, 201214 yr never heard of electrical problems with Ossas, I should speak to the factory or English importer if no ones near you.
June 12, 201214 yr One of the lads i go practising with had a similar problem turned out to be the ecu in the air filter box the connectors had gone a nasty green colour he cleaned the connectors with contact cleaner.... seems fine now worth a look...
June 13, 201214 yr i noticed my ecu connectors where a bit ropey so i cleaned them and the used a bit of silicone grease when i plugged it back in to stop the water getting in. one of the 2013 mods is to mount this ecu externally on the motor to allow better access for the air filter to be changed, i hope they get it sealed up ok jsp Edited June 13, 201214 yr by jsp
April 2, 20215 yr Hi I'm having the cutting out problem when at cetain temp on my ossa 280 2011 does anyone no where I could take that specialise on ossa near Manchester thanks in advance
April 2, 20215 yr 52 minutes ago, scubadaz said: Hi I'm having the cutting out problem when at cetain temp on my ossa 280 2011 does anyone no where I could take that specialise on ossa near Manchester thanks in advance Birkett Motosport were the UK importer. Nearly 2 hours north from Manchester, but may be worth the drive to get it sorted correctly. https://birkettmotosport.com/
