January 3, 201313 yr I have brought a ty250 and it needs a new back rubber, any suggestions on what Tyre is best for will be best for it, Thanks
January 3, 201313 yr Depends on the type of ground you ride on. Take a peep at what the better riders in your area are using a go for that.
January 3, 201313 yr It's a tube type rim and normally the Yamaha rims won't successfully seat a tubeless tyre. It will pop out ok when fitted, but once the pressure is down to riding pressure they usually drop off the rim - at least all of those I've had did (twinshock or mono) Others may have found differently? The only tubed tyre is an IRC. The Michellin tubed tyre is as good as a racing slick in the mud, useless, it's nothing like the old X11 tubed tyre
January 16, 201313 yr Industry Standard...The Michelin is THE tyre, how many world class riders use anything different!
January 16, 201313 yr Industry Standard...The Michelin is THE tyre, how many world class riders use anything different! Not on a tube type rim, IRC tube type for twin shocks.
