I Purchased A Beta Evo 250 2012
Six months ago I purchased a 1999 Beta Techno 200 to see if I liked trials....I did. I then sold that and purchased a 2002 Beta Rev 3 250 which was great. I've now sold it and purchased a 2012 Evo 250 which has cost me alot more than my previous two bikes put together!!
Please tell me I've purchased a good bike!!!! :hyper:
Is there anything I need to keep an eye on apart from the obvious stuff?
Cheers
Ash
you chose well ash just keep the air cleaner clean and grease the swinging arm and linkage bearings 2 or 3 times a year and you wont go far wrong .i give mine a spray all over with wd40 after every wash too to keep the fastenings from rusting (i know some people dont recomend it but ive not had any bother in all the time ive done it )
You've bought a brilliant bike !!
Before I bought my 2010, my mate descibed it as the closest thing to cheating as you will find !! It's like riding a push bike !!
As far as maintenance goes, regular oil changes and as has been said previously, grease swing arm and linkage bearings now, because they probably haven't been done, unless you know otherwise . After washing I always take the cover off the alternator and spray with WD 40 just for piece of mind .
Enjoy !!
Phil
I love mine. easy to work on & maintain. I love to by stuff for it that it doesn't need.
as pistonbroke says flywheel cover off and a quick spray in there after each wash great bike
Cheers for the tips folks. Collect the bike on Friday, If anyone is at Earl Shilton Trials club on Sunday I'll be the one smiling like a cheshire cat!
Do you take the flywheel off before spraying Windings etc?
No just the cover to expose the flywheel and then a liberal coating all around with WD 40 or similar.
Phil
I am being a bit thick here but how does the wd40 get past the flywheel or are there holes in it. I own a rev 3 which has a flywheel weight over the flywheel so cannot get to windings
Just collected my Beta Evo, I'm staring at it from my office window wondering if it looks bad if I suddenly become ill at work and need to go home!
I too have a Rev3. I removed the weight when my coils died. I had it repaired and did not bother putting the weight back on.
I'm glad I did'nt put it back as the bike is much nicer to ride. If I were you I'd remove the weight which will allow you to spray in WD. I reckon you will like how it feels as well. You can always put it back on if you don't.
The windings rot from the inside out so you don't see the damage until it is to late. Mine looked fine but it was dead as a dodo when tested.
