An Easier Way To Remove The Clutch Basket?
Ok I'll admit that some of this BS is just a stalling tactic, I was waiting for one of our antipodean TC cousins to make a contribution to the original post question. In the back of my mind I can barely recall someone (Neo?) fabricating a holder tool out of plywood...or did I dream that? It must be great to have a memory?
  • Replies 50
  • Views 27.1k
Most Popular Posts
  • Time is money?? - This is a guy working on his own bike at home.....
  • never used a torque wrench in 30 years of working on bikes. Still waiting for the first problem....
  • Ok by way of explanation impact gun for removal and re fit of clutch, primary gear and flywheel nut. mark it before you remove if you like but the gun i have only just manages to get these things off
You'd laugh if you saw the tool I made for doing mine, wanted to spread the load as much as possible to prevent the possibility of grooving the hub. Will take a photo & post it up later
Haha, post up the picture I want to see it now :)
You asked for it, the pins on the inside fit the hub firmly the full length of the hub which means the there is no possiblity damaging the hub. A bit of overkill but I was able to make it fairly quickly at work 1 night
Edited by tony27
Don't tease us Tony, the atttched images are blank with the message;
'th is person moved or deleted this image' :huh:
They were there when I first posted, will have a look to see what happened & fix it
Looks like it didn't like me moving the photos into the folder of my sherco stuff rather than an undefined folder after I'd posted them
Edited by tony27
