An Easier Way To Remove The Clutch Basket?
When I replaced main bearings on my Sherco I had problems getting the clutch basket off. I remember looking at the proper tool and thinking it was expensive for what looks like 'old clutch plates' welded together... so when I replace my clutch plates in the future I will be keeping the old ones and making a tool. Chisel / grind off the friction pads and weld / bolt them together and then weld some sort of handle on.
You can buy a new set of friction & plain metal clutch plates for a tad over £80 and use the old ones to make a tool. Clutch basket removed & new clutch for £10 more than the tool just to get the basket off...
Like others here I used a impact drive gun to rattle the nut off. I found getting the primary gear nut off more difficult, it took about 15-20 seconds with the rattle gun before it shifted. I thought it was never going to come off!
  • Replies 50
  • Views 27.2k
Most Popular Posts
  • Time is money?? - This is a guy working on his own bike at home.....
  • never used a torque wrench in 30 years of working on bikes. Still waiting for the first problem....
  • Ok by way of explanation impact gun for removal and re fit of clutch, primary gear and flywheel nut. mark it before you remove if you like but the gun i have only just manages to get these things off
If you buy the sherco tool thats one job sorted, however if you buy a compressor and an impact gun you will be able to do loads of jobs. Go buy a compressor, Copemech is correct doing the job without the right gear is just more expensive in the long run
Edited by baldilocks
If you want to use the correct tools use a torque wrench rather than an impact gun.
Impact Air gun, by the time you've bought a clutch basket and a holding tool you could have got a small second hand compressor and a second hand air gun.
Mark the position of the nut before undoing. Impact gun indispensable.
Impact gun for removal
Torque wrench for install
Both tools worth every penny after just a few different repairs. Motorcycle, automotive, tractor, whatever.
Edited by zippy
Cheaper, and you get to tighten everything to the corect torque. Torque wrench indispensible. :P
If you haven't got / don't want to buy a compressor then one of these...
CEW1000.html'>http://www.clarketools-uk.com/acatalog/CEW1000-1-2--Drive-Electric-Impact-Wrench-CEW1000.html
will do the job. This is what I borrowed off a mate and ended up buying one. Great bit of kit for
Yeah I've decided I'm going to remove the basket with an impact gun, and ill just tighten with a ratchet until its tight enough.
Now with the new clutch basket, I'll need to rivet the gear assembly on to it. Do any of you guys have experience with this and have any tips? or is it just standard
thanks for the help
If you have to use a rattle gun to get if off, chances are you will have to use one to get it tight.
I guess it takes a bit of mechanical sympathy !
(unless your ham2 fisted)
There are those "Old Boys" that seem to have a torque wrench fitted inside their wrist. and can actually get the torque within a couple ft/lbs of what it needs to be.
Each to their own I suppose; I've never used an impact gun in 28 years of working on bikes, and similarly have never had any problems. I'm not saying its wrong to use one, I just don't see what advantage it gives.
