My 90's Gas Gas Contact250 Project..
  • Replies 186
  • Views 38.8k
Most Popular Posts
  • J if it were me I would check out reed block up-turn and dump any fuel that has got into the crank heat up a good plug and maybe a squirt of easy start. failing that....... go for a beer ;-]
  • thats_a_five
    thats_a_five
    You say you turned the bike upside down and "a fair bit of fuel came out." Just to be clear, there will be fuel that comes from the carb bowl. That is not a problem, it is just the bowl draining.
  • Check the stator and HT lead then. Although your spark appears ok when out and against the frame the spark is only under atmospheric pressure, when under compression the stator may not be producing th
I don't remember you ever saying, what does the air filter look like?
Also you said there is no t-stat. So two things come to mind.
1) What is in the head filling the hole the stat threads into?
2) Without a stat (or the rest of the electronics wired in) it is probably un-wise to ride it.
Been told to turn the fuel screw in all the way and work it out half turn at a time as the plug is getting soaked after a good few kicks? Nothing to lose!
The airmfilter isn't the best, its clean but misshaped. The airbox etc isn't fitted at the moment?
If I'm honest, I can't even find where its supposed to go in!
Today is the day! I can sense it!
It's popping every kick, (massive flames on some of the kicks from exhaust!)
I turned the fuel down as my mate suggested and it tried to start twice!!
Now I'm tired so taking a break then going to try again..
Right, she has run (only for about 2 seconds though) :(
Mate suggested taking off exhaust and it sounded like it was restricting it. First kick we had some massive flames and run of its own back for a few seconds. Looking in at the piston its very oil and greasy in there so going to whip the head of and give it a quick clean up.
The kickstart lever has bent now too! Just spent an hour modifying the good base with the good lever so they work together!
Need a break now. Never been so tired!
Can't get the kickstart sorted, local shop has nothing else that fits. I have found genuine Gas Gas ones online but at around £100 its alot of money! Worst thing is I read on one that its a 16mm shaft, I make mine out to be 13mm?
Any ideas?
What do you guys think? Is that letting too much past the piston?
ive seen your other video on youtube "Gas Gas wont start" and there is no pipe on i think this is the reason for it not running fully
on 2 strokes back pressure is critical for it to run properly. when theres no exhuast theres no backpressure( i think!)
I took the exhaust off to aid starting (which helped as it nearly started) I have tried for the last couple of weeks with the exhaust on.
It is VERY hard to kick over, i know what you mean, I did make it look easy (must be my iron man legs I have grown!)
Any ideas?
Think my 95 jtr is a 14mm shaft, got my kickstart lever from gas gas.
TLTEL
I did think that but when I heard the suction noise as the piston went down it had me worried. Suppose all I can do is clean the top of the piston with brake cleaner and wire brush (gently?) refit it all tommorow and see what happens?
