April 19, 201313 yr Just spent an afternoon doing some relatively high-speed single-track trail riding and noticed two odd noises: 1) shifting from third to fourth produces a dramatic CLUNK, and 2) fourth gear whines loudly, unlike any other gear. I've only had this bike a short while, but never noticed these noises before. Then again, I rarely went past third gear, so it could have made these sounds and I just didn't notice. Are these normal for a 2012 Pro with less than 15 hours? I recently replaced the oil, which was ATF, with more of the same (about 400cc or so - level is 3/4 up sight glass). I don't notice any difference in clutch action. Thanks for your input.
April 19, 201313 yr Third to fourth is always noticeable. The whine is some what normal. These transmissions are very weak. High speed trail riding has to be done carefully. Keep on eye on the oil for fragments. The needle bearings are prone to coming apart with hard use.
April 19, 201313 yr Author Thanks for the feedback, lineaway. I'm relieved to know that these sounds may be normal, but I'm concerned about this need you mention to be "careful" during high-speed trail riding. I'll certainly exercise care, but exactly what should I be careful about? I don't do clutchless upshifts or stomp on the gear change lever or anything else that can be hard on a transmission (that I know of). But maybe I'm unaware of something that can be harmful in this case, so please educate me.
April 20, 201313 yr Riding the pro like you would any trail bike. Will break the tranny in no time. If I shifted the pro like my old Yamaha that I desert raced, it would have several major problems. I have a friend that came to trials, having several KTM`s and a few street bikes. He has a 2010 pro that we replaced the whole tranny in 2011. It was just from down shifting what would be considered `normal` on most bikes!
April 20, 201313 yr Author Okay, so you're saying I shouldn't shift my GasGas like I do my KTM's, but I still don't know what I'm supposed to do instead. Do you mean that I should do as little shifting as possible while trail riding, or that I shouldn't do trail riding at all on this bike? I'm new to trials, but I just attended a two-day trials riding school and learned from multiple instructors that I can be much harder on my GasGas clutch than I would have ever imagined - I'd never start a huge hill climb from a standing start in third gear on one of my woods bikes, and then slip the clutch the whole way up, for example. But that's how we were taught to do it on a trials bike at this school (and it worked great). Same thing applied in lots of other situations, too, and I developed a very different relationship with my clutch than I'd ever had on any dirt bike or street bike before. I now do much, much more clutch-slipping on my trials bikes (I have an old Montesa 315R, too) than on any other motorcycles. I understand (a little) that in competition, a trials rider most often selects a single gear for the section at hand, and just stays in that gear the whole time, relying heavily on the clutch instead of shifting up and down. But nobody at the school said anything about trials transmissions being fragile and unable to take the stress of "normal" shifting (and we even went on a trail ride with one of the instructors at the end of one day). Is this a GasGas issue, or does it apply to all trials bikes?
April 20, 201313 yr Trials transmissions in general are usually not fragile, just the pro. It is a strange design found only in the pro. Mainly the shift to 3-4 and back down 4-3. But in general the whole thing is not a strong design. You need to search the forums and you will see pro tranny problems over and over. The bike works very well, but has always had the most repair issues. Everyone says the newer bikes are better. Just use the brakes more, and not hard shifts on the trail.
April 20, 201313 yr This video will show how small this gear box is to the old reliable transmission.
April 20, 201313 yr Third to fourth is always noticeable. The whine is some what normal. These transmissions are very weak. High speed trail riding has to be done carefully. Keep on eye on the oil for fragments. The needle bearings are prone to coming apart with hard use. A friend of mine described the Trans in these things as a "High Performance Nightmare" Some parts of a motorcycle shouldn't be compromised for the sake of light weight.
April 20, 201313 yr Author Thanks for the clarifications; I understand much better now and will take extra measures to baby my Pro's transmission!
April 21, 201313 yr they are designed for trials so they are not going to be the most reliable things ever built. but should stand up to a bit of trail riding. (just be smooth and gentle). i ride mine round our fields pretty quick and have had no problems-but theres a big clunk going from 4-5th. the last thing on gasgases drawing board is reliability and strength- they want it to be light weight so they have to cut down on things like a reliable engine thats heavy. and go for a small weak one instead.
September 7, 20251 yr Erm how somewhat normal is the whine in 4th? Because Ive got a 2017 txt 300 and when I go into 4th It sounds like the box is about to blow up On 4/19/2013 at 1:19 PM, lineaway said: Third to fourth is always noticeable. The whine is some what normal. These transmissions are very weak. High speed trail riding has to be done carefully. Keep on eye on the oil for fragments. The needle bearings are prone to coming apart with hard use.
September 7, 20251 yr 15 hours ago, SamAs said: Erm how somewhat normal is the whine in 4th? Because Ive got a 2017 txt 300 and when I go into 4th It sounds like the box is about to blow up It should NOT sound like it's going to blow up! But 4th gear is "complicated" and actually requires 3 gear pairs to create the ratio. Here is a link to a YouTube video that demonstrates this, as well as the original GG patent in Spanish: https://www.electricmotiontech.com/home/em-factor-e/clutch-gearbox#h.2ajazdf2rs5
September 10, 20251 yr It may not exactly sound like it’s going to blow up, but it is very whiny. I would include a video but cannot post iPhone videos. I can hear it whine when in 4th but 5 and 6 are fine I believe however the change up is clunky 4/5 I put it on “trials bikes uk” Facebook group on Sunday afternoon and the general idea is that it’s normal anyway On 9/7/2025 at 4:30 PM, konrad said: It should NOT sound like it's going to blow up! But 4th gear is "complicated" and actually requires 3 gear pairs to create the ratio. Here is a link to a YouTube video that demonstrates this, as well as the original GG patent in Spanish: https://www.electricmotiontech.com/home/em-factor-e/clutch-gearbox#h.2ajazdf2rs5
