ahell Posted December 14, 2015 Share Posted December 14, 2015 1. quick throttle (white) domino 2. Twin air filter (and delete back fire guard) 3. delete automatic cam chain tensioner and install amanual one. (mitani or other for 250 crf) 4. 10x42 Quote Link to comment Share on other sites More sharing options...
guys Posted December 14, 2015 Share Posted December 14, 2015 3. delete automatic cam chain tensioner and install amanual one. (mitani or other for 250 crf) What's the advantage of that? Quote Link to comment Share on other sites More sharing options...
jimmyl Posted December 15, 2015 Share Posted December 15, 2015 The new rear mudguards are more rigid than the '05 - '13 models, so they tend to tear through the mounting holes where the guard screws into the airbox. I've plastic welded the supports and the guard can still tear away. Last weekend I saw a different approach, cut an inverted "V" so that the guard actually comes away from the bike easier - and without tearing.and#160; or Put latest rear mudguard in the garage for when you sell it or for summer evening trials and fit the old pre 2014 rear mudguard. Got fed up with a muddy back as new ones are fashionably thin but in fact the worse thing on my 2015 - even worse than the stand PS Got to have something to moan about. 2 Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 15, 2015 Share Posted December 15, 2015 Might be that there are 2 types of rear mudguards. Gas Gas has this, one hard one for registration plate purposes, and one soft one. Quote Link to comment Share on other sites More sharing options...
guys Posted December 15, 2015 Share Posted December 15, 2015 Might be that there are 2 types of rear mudguards. Gas Gas has this, one hard one for registration plate purposes, and one soft one. Nope, not for montesa, they use a plastic (pré 2014) or a steel (2014 and on) support, for lights and plate, that bolts on under the original rear mud guard. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted December 15, 2015 Share Posted December 15, 2015 Might be that there are 2 types of rear mudguards. Gas Gas has this, one hard one for registration plate purposes, and one soft one. There are 2 type of 4rt rear mudguard Post 2014 that are fashionable and narrow and as much use as the proverbial chocolate tea pot and Pre 2014 that actually do what they say - keep the mud off . I haven't crash tested a new one but the old version are as tough as old boots and will bend in half and then just shrug it off, I know!! 1 Quote Link to comment Share on other sites More sharing options...
betabonkers Posted December 15, 2015 Share Posted December 15, 2015 Perhaps you have a wide back Jimmy 1 Quote Link to comment Share on other sites More sharing options...
jimmyl Posted December 16, 2015 Share Posted December 16, 2015 Perhaps you have a wide back Jimmy 2 Quote Link to comment Share on other sites More sharing options...
betabonkers Posted December 16, 2015 Share Posted December 16, 2015 Hahaha Quote Link to comment Share on other sites More sharing options...
ahell Posted December 20, 2015 Share Posted December 20, 2015 What's the advantage of that? reduce the engine brake and increase power. It's a little thing, but with the rest of the mods it's nice. 1 Quote Link to comment Share on other sites More sharing options...
cmxi Posted December 25, 2015 Share Posted December 25, 2015 (edited) reduce the engine brake and increase power. It's a little thing, but with the rest of the mods it's nice. i dont se the connection between the cam chain tensioner and increasment of power and engine braking.on crf's you replace the oem cam chain tensioner due to the spring inside gets soft and will not put the correct tension on the chain.. so you replace it with a fixed unit. Edited December 25, 2015 by cmxi Quote Link to comment Share on other sites More sharing options...
billyt Posted December 25, 2015 Share Posted December 25, 2015 (edited) Cam chain tensioner reducing engine braking and giving more power ????? I suppose you will tell me next that I can convert my four stroke to a two stroke by removing two of the strokes ????? Edited December 25, 2015 by billyt 1 Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 9, 2016 Share Posted January 9, 2016 Actually a loose cam chain tensioner might cause some extra holes in your engine = 2 stroke 1 Quote Link to comment Share on other sites More sharing options...
ahell Posted January 11, 2016 Share Posted January 11, 2016 (edited) Cam chain tensioner reducing engine braking and giving more power ????? I suppose you will tell me next that I can convert my four stroke to a two stroke by removing two of the strokes ????? Please try to turn your rear wheel with and without the 2nd chain tensioner ... any difference ? I'm sure you understand now. It's the same in supermoto with o-ring chain and classic chain. low friction, best result. Regarding the timing chain with manual tensioner, less engine brake is right, more power ... i can't feel the difference. Edited January 11, 2016 by ahell Quote Link to comment Share on other sites More sharing options...
ahell Posted March 20, 2016 Share Posted March 20, 2016 (edited) Last pictures of my 2016. mitani timing chain tensioner mitani full titanium exhaust alloy Tech fork Texalium clutch cover guard CSP modified (lighter) skid plate S3 alloy footrest Jitsie alloy chain tensioner Jitisie 5.5 inch handlebar (renthal grip) Twin air filter & white throttle. Jitsie 42 fim Freno pads Repsol 2015 black frame stickers Repsol 2016 swingarm and fork stickers Jitsie black number plate ... Edited March 23, 2016 by ahell 1 Quote Link to comment Share on other sites More sharing options...
