Budget Trials Build
Finaly took the tyres up and got them properly on the rims, they´re straight now, will see how the tubless rear holds once I start ridin :D
The fuel tap and airfilter arrived which fit just perfectly.
Had to start with the cables since I can´t get the flywheel off, so orderd a puller and a new clutch cable since the one I had is sticking like grazy and isn´t a good fit, throttle wasn´t also a bolt-on... neither is it nice but works good.
With a new chain the bikes starts to look like an actual motorcycle.
Hoping to sort out the motoplat, but still have the front engine mounts and an exhaust on the list.
  • Replies 88
  • Views 30.3k
Most Popular Posts
  • Place is starting to take shape with the bike... today I got a Telwin, going to need a welder for the engine mounts and rear subframe and pretty sure it won´t end there. Just need a new balloon sinc
  • Finaly something is happening Today I started with the tyres, put on a new rimtape and inners + used Dunlop D803´s Although forgot the soap and didn´t really have the right tools so one sid
  • Yep and maybe some wamth will also help, in my garage there´s 5℃, so gonne take the weels to the workplace and keep them inside overnight. Pretty sure warmth, lots of soap and a compressor will do the
Raer mudguard from a GasGas TXT, will fit with some modifications so can start with the subframe and engine mounts. New grips and a clutch cable.
Still nothing from the ignition part, but I got the puller and seems like sombody has changed the stator, because it looks like there´s been some milling done there...
7 hours ago, katana said:
Coming along nicely!
Thanks
1 hour ago, oni nou said:
When you finish that I would like to see Takumi Narita ride it .....that would be something worth watching.
Holy moly, this guy is crazy!!!
Didn´t get a change to visit the garage for a long time but today started working on a new ignition system, just thoughet it easyer and cheaper then messing with the motoplat!
Got a chinese pitbike cdi ignition and hoping to get it working though it will need some pretty seriouse mods.
Gonna keep the plate and had to also modify the magneto, because it woudn´t reach the cone.28580456_1673743849335564_1329998186_o.thumb.jpg.4b1d009f125e874630e60e2abb41bb5d.jpg
The plate is also taking shape but now comes the biggest problem, the ignition doohickey is external and doesn´t fit the housing!
28641240_1673743872668895_1650806746_o.thumb.jpg.2c732e2ac3076fea4f8d4fbfe1326e29.jpg
Also got a new project for summer :) It´s a Honda Dominator, so when waiting on parts or just get too frustrated I can work on that.
Good god I´m an idiot!!!
Got the chinese ignition working and had a feeling I should try the motoplat again before gutting up the engine, because the impulse generator woudn´t fit otherwise.
So after taking it all apart and reinstalling the original parts I discovered I hadn´t attached the green wire previuosly and well, that was the ground for the stator ....<_<
Wasn´t sure but had to give it a go and this time I made a 17mm socket fit a drill and when I got the engine spinning there was a beautiful spark!
28755398_1678703712172911_1911328058_o.thumb.jpg.76ef090aeabf260ef316ff59ae5197eb.jpg
Unbelievable how stupid I could have been, so now, I´m gonna tighty up everything, set the ignition and make the front mounts!
Even without the exhaust it would be the first time the wheels start moving on this badboy! B)
14 hours ago, zippy said:
I am enjoying the trip this has been, your enthusiasm for this build is great.  :thumbup:
Thanks, I had forgotten the awesome feeling of achievement when things start moving the right way...and how much you can learn from every mistake :)
I´m loving it! :D
Today was a very work oriented day but squeezed some garage time in as well, had to clean up the place because I saw and add touring the weekend and couldn´t resist - so now I also have a Honda SLR with a gearbox problem.
One car and 4 motorcycle isn´t a good idea in s 3x6 space.
But luckily I have a tunnel there, so now there´s rome for actual work and I started with the front mount. Won´t be pretty but for version 1.0 I think they´ll do the job, some welding, a few supports and we should be golden.
I am just waiting for the first video of you riding it...  When I get a bike I strip and rebuild.  I replace what is worn or damaged and end up with an as new bike.  I couldn't do what you do.
I must admit :D what you do is much more reasonable!!! I would go the same way but since this started so long ago it would be awesome to finish and I´ve enjoyed these last months too much B)
Was away for almost half a week and today was a short one, so made the kickstarter fit and tacked the front mount, hoping to get it running the next time I´m in.
29136326_1686377908072158_1804616666458357760_o.thumb.jpg.38614ef484af104a879aeb7950dd0b2f.jpg29196675_1686377921405490_5876670547001081856_o.thumb.jpg.c68757cd0f381ba4d7df4e673906daa7.jpg
So close, but still so far :)
Buttoned up the engine mounts and got the wires routed, I´ll add some plugs and a propper wiring once everything is working.
Also made the starter button a kill switch, and made the clutch cable fit but I don´t have enough movement for propper disengagement.
The last owner made the linkage longer, so I´ll have to return it to a shorter version.
Still didn´t get it started and without the clutch I couldn´t push-start it either, can´t get enough grip on the concrete, once I get the clutch working I´ll take it on a field nearby or something like that!
29214057_1688561554520460_5737981423038496768_o.thumb.jpg.4983083290bc2b04103217621af6dc54.jpg29216652_1688561521187130_2852436687789752320_o.thumb.jpg.02bcfef4e213b0814a158565051e9c25.jpg
Small steps after a long time.
Started on the exhaust, I´ll be basing it on a Husqvarna WR250 and hopefully make it fit.
The clutch is still a concern, even when compressing to lever on the engine it won´t fully disengage, so I´m quessing I should take it apart again and give it a proper cleaning, especially the plates between the disks.
Also tried to check the timing but the borrowed strobe didn´t work, so waiting on another friend to help me out :)
Edited by andrep
  • 3 weeks later...
Hey guys, haven´t posted for some time.
Tried to get the MX5 out of the garage only to find out the alternator had rusted shut, so took it apart and cleaned everything but it´s still not charging so I´ve been dealing with this and some mold + rust and well, just maintenace in general because I want to have it wokring properly although last year didn´t really drive it.
But, there´s heaps of space in the garage now, though I also have to rebuild the tail on my Jawa, because we´re going on an anual oldtimers ride in the end of this month.
SOOOO, a small brake from the Beta but will be getting back to it as soon as possbile.
30652813_1720445627998719_5939601043477233664_n.thumb.jpg.43a2d334a8f65e4f904b19651fbd8107.jpg
ALL THE SPACE!!!!
  • 9 months later...
Well, this small brake turned into a year... almost :D
But, all is not lost, just been extremely busy and been dealing with all kinds of other stuff, today felt like a good time to pick up this build.
I haven´t been to the garage almost half a year, was happy to find everything in place and nothing stolen :)  Now I finaly got gas for the welder and switched out the wire, dear lord, it´s a complitly different machine now!!!
Filled the gearbox with ATF and hopefully it will start working, so as soon as I finish the exhaust I´ll try to get it running before building anything else (maybe just the subframe so I could push-start it)
50927104_1140486096112222_371925789668540416_n.thumb.jpg.ba3ca3e07ab150141729201340738ba0.jpg
Made an exhaust flange from 5mm steel and cut up the donor pipes.
51492393_556341488176242_6745976373002633216_n.jpg.b96cc82987fbe81b152291dfe4c333d0.jpg
Now it´s starting to look like something...
51509279_622248771575800_9079451522466578432_n.thumb.jpg.7f6382a1efdae3749fed426ac53bb968.jpg
50910817_804901679843357_2884718572519555072_n.thumb.jpg.42d80101513b735a420658e928789c1e.jpg
Just need to properly weld it up and make a bracket or two and deal with the muffler once the subframe is finished...
Edited by andrep
Excellent work, (thought you had been abducted !) exhaust as shown might lack bottom end power ?
