Front Brake Lining Material
Thanks for trying, even the little you found out, and eagle8 added helps.
Much appreciated, Cheers.
  • Replies 32
  • Views 13.6k
Most Popular Posts
  • Discs can be severely heated and not affect the hub, but if you heated up a drum to the temperature that people heat discs to to water-quench-clean them, the bearings would fall out and the grease wou
  • Hi guys,   Sorry can't give you the trade name of the 'woven' material. I rang Villiers Services who did my shoes yesterday and asked the question but they send the shoes to a 3rd party for then lin
  • Ok guys some feed back and thanks for all the interest.   I made up a 2.5mm 'wire' cable rather than 'rope' however it was galvanized rather than stainless which I believe is slightly stronger but d
That sounds like the sort of lining i use for my tlr 250 and i've been told it's for fork lifts, so it's made for a harsh environment ie oil grease and other things that may be on a factory floor
the lining is not oil and grease proof. it is designed to operate a low speed and low temperature. try bringing a drum
braked trials bike to a halt quickly from road speed and feel the brake fade!
It seems to work pretty good on my TLR & is great when wet! the forklift drivers i see in factories & on the Wharves go a lot faster than my TLR!
