'09 Sherco 320 4T Rebuild Blog
Hi...I have a 2009 4T great bike when running but very hard to start when hot so have gone back to 2t Sherco much easier to start and ride.
Thought I would upload a photo of mine which I still have.IMG_20150321_172558175.jpg
  • Replies 122
  • Views 56.1k
Most Popular Posts
  • First up is the frame. It had a thick yellow coating, pretty hard, maybe powdercoated, but I'm not sure. I sand blasted the rusty bits, and used a special fiber disk with the angle grider to get rid
  • Reached my file size limit. Some more:
  • beta_blocker
    beta_blocker
    Hi Proper I have a 2009 320 R which I've had for about a year and have learned quite a bit about it and may be able to help you with some of your questions and your rebuild. the shock probably has l
  • 2 weeks later...
The OKO 24mm has been ordered, along with a bunch of main/pilot jets. The Sherco has the typical single piston 4T hesitation when cranking the throttle. Let's see if the OKO can work wonders. Will take a few weeks before it arrives.
What's next? I removed the flywheel nut with the air impact wrench. The flywheel has a M31x1 external thread. I did not find any after market flywheel puller that size. Impossible. Why, Sherco, why? To sell your own flywheel puller for top price? Not happy.
There are no other attachment points for a universal gear puller. The Flywheel can not be pried form the back, and I don't want to hit the crankshaft with a hammer either. Bugger.
Now what? I'll have to sleep on that one. You'll probably say: buy the Sherco puller from the money you saved on the OKO...
The head will be removed tomorrow. Didn't want to wake the house with the air impact wrench. Not much room for normal 12mm sockets up there.
Exhaust has been blocked on both sides. One side has a clamped rubber grommet, the other side a flat plate with sponge rubber. Needs the gas burner at work the get it red hot. Let's see if those nasty dents can get sorted.
Noticed your crank does not have the 3rd bearing ''nub'' on the end which a 2009 3.2 should have...maybe a non-original motor in frame or actually an older model sold as a 2009?? If its actually a 2009 model it should also have the Sps carb already installed, easily identified by a round aluminum main jet access plug(its a modded keihin PWK28) . With this carb you will have Zero ''off idle hesitation/sputter at all...but you have to make sure there is no crap in Any of the jets or orifices.  That is a very interesting looking coffee can welded onto your header pipe there...very unique:mellow: Good luck on your build
Thanks for that piece of information, Paul. Will check the carb tonight. That seems to be the best telltale.
Last night I was thinking: what if I could 3D print a M31 nut. That would give the gear puller something to pull at. Probably not strong enough, but worth a try.
Anyway, a M31x1 tap is on the way from China.
If there's any interest in an affordable 320 flywheel puller, let me know. I'll only produce one batch of them.
Well, at least it's a Keihin. And it has the SPS float bowl nut. Now I'm puzzled. Maybe it's a 2005 - 2008 version converted to SPS?
388248dc-18f5-40b5-8dd0-dd0988dd7552_zps
Edited by proper
If you unscrew the said float bowl nut, It will have a longer atomizer tube with a Dellorto mainjet on bottom (will have loose jet and spring and small end thing :huh:inside if its sps or converted) The 2008 came with a regular pwk with hotstart setup. I am thinking you may want to recheck your reg. papers as the crank indicates that it is not a 2009 model unless its been replaced or something..:popcorn:
Oh..I just noticed both vent spigots one each side dont look like they or ''open''. If not, they are on a Sps...may be someones previous attempt to update/carb change, not sure about pwk 2t variations etc I know there are several...Guys at splat are one of the very best for info and parts. Enjoy your build
O well, I don't really mind what year of build it is. No reg papers, no serial (should there be any?). I'll give the OKO 24mm carb a try, because I'm curious what it does. In a couple of months time the bike will be ready to ride some entry level club trial. Can't wait to hear that bark again. Thanks again for your help. Appreciate it.
Vincent
Popped the head off. Clear signs of threadlock on the camgear bolts. Must remember that. All looks well. Cam chain guides are like new. The cylinder head gasket looks fine too. Valves are next.
Edited by proper
Vincent
Engine number should be above the swingarm pivot
I might not like the meaning of this...
Story is that this particular Sherco has been used at expert level regional club championships. It's a Cabestany replica. The serial seems to point to a 2005 version?
Yeah, I know, the crankcase needs fresh paint.
Edited by proper
The OKO arrived today.  Actually looks pretty good,  considering it's low price:
IMG_20170220_193814272_zpsmbuhjeoz_edit_
IMG_20170220_193834072_zpsyfavyhcr_edit_
IMG_20170220_193848208_HDR_zpsiteu0zak_e
I re-read this great post by Vic:
and realized I had skipped the step of checking the rocker arm bearing roller for deterioration. Indeed, the exhaust rocker roller has huge play, and can be twisted. This play probably accounts for the increased exhaust valve clearance.
I had a quick peek at splatshop, and wasn't disappointed. It's not a cheap part.
The rocker arm is fine, it's just the bearing roller needing replacement. So that's what I'm going to try. It isn't meant to be replaced, the bearing shaft is welded. (never seen such a perfect micro weld). I'll drill the shaft, and try sourcing a replacement roller, mounted on a precision 12.9 bolt.
At the inlet valves I measured the following:
Valve 1: gap 0,00mm   Shim 1.26
Valve 2: gap 0,05mm   Shim 1.26
Shim thickness was measured using a micrometer with a 6.34mm bearing ball in the shim recess. Double checked with the digital caliper.
Here's the shim sitting on top of the valve stem. It took me a while to understand how to remove them. It turned out it only needs a magnet:
Marked all the shims and valves postions:
Piece of wood to compress the valve spring:
I'm using a deep-throat bar clamp to compress the valve spring:
But the spring will not compress. I'm afraid of giving it more pressure, as it feels pretty solid. Don't want to bend valves. Any ideas what's going wrong? The piece of wood is clear of the casing, the clamp sits directly on the valve. The stem doesn't move up in the cap.
