mikerenief Posted February 1, 2017 Share Posted February 1, 2017 I'm going to have to remove the headlight in order to put on my number plate - there is the light and mapping button mounted on the backside of the headlight. Did any of you TRS owners figure a nice and simple way to move it? thanks cheers Quote Link to comment Share on other sites More sharing options...
baldilocks Posted February 1, 2017 Share Posted February 1, 2017 Hi On mine I've just removed the light switch further back from the headstock at the connector. For the mapping switch I made a loop to shorten the cable then zip tied this to the clutch hose where it enters the frame behind the headstock. Map 1 doesn't seem short of power 1 Quote Link to comment Share on other sites More sharing options...
mikerenief Posted February 1, 2017 Author Share Posted February 1, 2017 Thanks. that's an idea. I'll try to do something behind that number plate to keep it safe from pinching. The light I actually don't even need, just the mapping switch. you're right - lots of power Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted February 1, 2017 Share Posted February 1, 2017 (edited) 1 hour ago, baldilocks said: Hi On mine I've just removed the light switch further back from the headstock at the connector. For the mapping switch I made a loop to shorten the cable then zip tied this to the clutch hose where it enters the frame behind the headstock. Map 1 doesn't seem short of power As an aside, I hadn't realised you'd gone TRS. Which one do you have? Any general comments on how it compares? Edited February 1, 2017 by cleanorbust Quote Link to comment Share on other sites More sharing options...
baldilocks Posted February 1, 2017 Share Posted February 1, 2017 (edited) Hi Cleanorbust Nothing wrong with the gas gas, Ive had 8 over the years but I just wanted a change. I've got a 280 RR and I'm very impressed with it. Admittedly I've only ridden it twice. Feels lighter than a gg to ride front end is more stable. Suspension / power awesome . At the moment all I've done is wound some off the rear spring and turned the mixture screw in about half a turn. Edited February 1, 2017 by baldilocks Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted February 2, 2017 Share Posted February 2, 2017 Thanks Baldilocks, interesting to get your view. Quote Link to comment Share on other sites More sharing options...
mikerenief Posted February 20, 2017 Author Share Posted February 20, 2017 Here is what I did for the mapping switch. just a piece of aluminum. 2 Quote Link to comment Share on other sites More sharing options...
andyjohnson_10850 Posted April 26, 2017 Share Posted April 26, 2017 I made a little bracket out of aluminium and mounted it behind the number board. Quote Link to comment Share on other sites More sharing options...
reggie Posted June 18, 2017 Share Posted June 18, 2017 It is possible to mount the mapping switch in the front void of the handlebar clamp pad. No need to make any bracket, I have had it there for several months without any troubles. Quote Link to comment Share on other sites More sharing options...
old trials guy Posted May 23, 2019 Share Posted May 23, 2019 I made up some of these with my 3d printer. 2 Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 24, 2019 Share Posted May 24, 2019 On 2/1/2017 at 4:27 AM, mikerenief said: I'm going to have to remove the headlight in order to put on my number plate - there is the light and mapping button mounted on the backside of the headlight. Did any of you TRS owners figure a nice and simple way to move it? thanks cheers Yeah, unplug it and throw it in the trash, Runs just fine with out it. 1 Quote Link to comment Share on other sites More sharing options...
