jsp Posted October 17, 2017 Share Posted October 17, 2017 I've just been looking at the spec on the rock oil I got with my bike and it dosen't match the castrol one that's in the manual, the rock oil is also nearly clear so its a pain to see it in the sight window as the red one that came in the bike you could see a mile away Lite_Gear_Oil.pdf Quote Link to comment Share on other sites More sharing options...
cascao Posted October 17, 2017 Share Posted October 17, 2017 In cars, ATF oil have to be changed in intervals like 100.000km. Why on motorcycles we have to change it after 100km or less??? Quote Link to comment Share on other sites More sharing options...
heffergm Posted October 17, 2017 Author Share Posted October 17, 2017 (edited) For the most part, volume. A car holds several liters. Our bikes generally only hold 400mL or less. I'm not an automatic gearbox expert, but I'd imagine they also do far less clutch slipping than we generally do, which means a lot less particulates in the oil. Edited October 17, 2017 by heffergm Quote Link to comment Share on other sites More sharing options...
turbofurball Posted October 17, 2017 Share Posted October 17, 2017 3 hours ago, cascao said: In cars, ATF oil have to be changed in intervals like 100.000km. Why on motorcycles we have to change it after 100km or less??? ATF usually needs changing at 50K ideally, engine oil at perhaps 10K on a modern car, or 3K on an old one. Most motorbikes use combined gearbox and engine oil, and have a wet clutch (rather than an automatic gearbox's belts and torque converter, which is a seperate fluid coupling) which means it all gets dirty faster; trials bikes also don't have an oil filter, which is why I can do 4K between oil changes on my Triumph but a fraction of that on the Gasgas. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted October 17, 2017 Share Posted October 17, 2017 4 hours ago, turbofurball said: ATF usually needs changing at 50K ideally, engine oil at perhaps 10K on a modern car, or 3K on an old one. Most motorbikes use combined gearbox and engine oil, and have a wet clutch (rather than an automatic gearbox's belts and torque converter, which is a seperate fluid coupling) which means it all gets dirty faster; trials bikes also don't have an oil filter, which is why I can do 4K between oil changes on my Triumph but a fraction of that on the Gasgas. Modern auto boxes have clutch packs very similar to pre diaphragm trials clutches and epicyclic gear sets very similar to the small gears in trials bikes. 2 Quote Link to comment Share on other sites More sharing options...
turbofurball Posted October 18, 2017 Share Posted October 18, 2017 Fair doos, I've never had to do work on a modern auto - probably for the best, lol 1 Quote Link to comment Share on other sites More sharing options...
jsp Posted October 31, 2017 Share Posted October 31, 2017 I'm not over keen on the rock oil, its that light you struggle to see it through the sight glass, where the red that came in it from new you could see a mile away Quote Link to comment Share on other sites More sharing options...
telecat Posted October 31, 2017 Share Posted October 31, 2017 We switched at the last change to the Castrol Transmax Z as Chris was losing clutch feel as the oil warmed. Not had any problems since. Helpful it's longevity seems to be good. Quote Link to comment Share on other sites More sharing options...
