Knocking front wheel
Hi just been out on my bike and felt the front wheel was knocking when I have the front brake on and gently push the bike forward and backwards you can see the brake disk is still but the wheel is moving causing a knocking feeling
Does anyone know what could be causing this I had front wheel off and only have one washer on the brake disk side between the fork and the spacer not sure if this could cause the problem or if I am meant to have anotger washer the other side
Any help with this would be great
It sounds like it could be the 'top hat' washers that go through the disk are worn.
Really really badly worn wheel bearings..
Or it could be your steering head bearings, but then the front wheel wouldn't move slightly.
21 minutes ago, tshock250 said:
Is it a floating disc?
Yeah it's s floating disk get no side to side movement just forward backwards
Still have the plastic disc guard on? Seems like I remember the caliper bolts could do some damage if the guard washers were gone. It made the mounting bolts too long.
Correct, first time I had the front wheel off I forgot to replace the disc guard and one of the caliper bolts protrudes too far if you do that and hits the disc/wheel assembly.
Glad to know I wasn't the only one...
I still have the plastic guard in place on my bike can't see anything touching just movement in the wheel forward and backwards but not the disk
I felt like a right lemon at the time!
I think it'll be your head stock. Floating disc does move but does not feel too bad through handlebars.Put a finger over the headstock end and move bike. Can you feel movement while applying brakes? If so that's it.
To make it worse.  I shortened the bolt and could not understand how I mixed it up, only to find the guard behind a shelf 3 months later.  To be fair, I stripped the bike when I bought it. lol
Just a heads up that some of the noise and movement will come from the pads moving within the calliper
If floating disc then try some silicon on the top hat spacers to take out some play.
Check non of the disc bolts have come loose catching the fork/caliper as tyre goes round.
as other say -check wheel bearings and head bearing etc
