February 27, 20188 yr Evening all, 2005 txt pro I have looked into this before by phoning gas gas uk, but seeking further opinions please. is it normal - when bike is on a stand, that there is a small amount of play in the linkage when lifting wheel - as it just doesnt seem right to me (although gguk said it was 'normal') I don't want to chase the impossible (no play) if its normal, but I also dont want to cause further problems by leaving it if it isnt 'normal' thoughts appreciated. cheers
February 27, 20188 yr Author Evening all, 2005 txt pro I have looked into this before by phoning gas gas uk, but seeking further opinions please. is it normal - when bike is on a stand, that there is a small amount of play in the linkage when lifting wheel - as it just doesnt seem right to me (although gguk said it was 'normal') I don't want to chase the impossible (no play) if its normal, but I also dont want to cause further problems by leaving it if it isnt 'normal' thoughts appreciated. cheers
February 27, 20188 yr My 05 does exactly the same. I removed much of it by wrapping a .05mm shim around the top bolt where it passes through the shock eye.
February 27, 20188 yr Author Thank you both. Bluey - do you mean the top bolt in the linkage (lower shock bolt) or the upper shock bolt? Cheers
February 27, 20188 yr Upper shock bolt - top of the shock. That's where the play comes from on my bike.
February 28, 20188 yr My 2003 has some up and down play in the rear linkage when on the stand. Not sure how much play, just that I can lift the rear tire and it is noticeable. The play is still there even after replacing all of the linkage bearings.
February 28, 20188 yr Author Thank you both for that. I tried to phone the GasGas UK tech dept today, but no answer ..... I just wanted to check that I didnt get the 'new apprentice' last time! Saying that, it is reassuring to learn that Zippy didnt get the play out with new bearings. Will try GasGas tech again though, just for another opinion. I am probably fussing, but I like things to be right on my bikes. Thanks again all.
February 28, 20188 yr It is normal to have some play in any bearing for lubrication. A bit of play in each linkage bearing added together and times the length of the swingin arm will = about 6mm.
March 1, 20188 yr Author Thank you Rich and Oni ..... 6mm probably sounds about right, although I havent checked the top shock mount. Will have a look once the weekend kicks in. Cheers - Andrew
March 8, 20188 yr Author Just to pick this up again ...... Top shock mount ok. Spoke to Andy, one of the tech's at gas gas uk and he said that the play is quite usual - not all bikes have it, but most do - even brand new ones. He and another tech, Kevin, have looked into this on a new bike and decided that the play (providing all of the componant parts are good) is down to the combined play between the bolts and the bearings and the grease gap in the bearings. So, the advice is ..... it is an inconsistant normality. Thank you all for your help on this - much appreciated.
May 16, 20188 yr I was having a think about this over the weekend.... is the play mostly in the rose joints on the shock? Or is it because the bushes on mine have disintegrated over time?
