rob[aut] Posted September 7, 2018 Share Posted September 7, 2018 (edited) Hello all, I bought a new 4rt european bike in feb already derestricted from the dealer. I like it really as it is my first 4st trials bike. A month or so ago a long time montesa driver told me, the idle was too high and he lowered it. The next time I drove it (week later or so) I wanted to drive a step down but it was too high and the engine protection plate had contact with a big stone and stopped my bike while I was still moving forward :-D The bike just fell to the side so not a big deal. But afterwards I had to kick about four or five times and it didn't run well and even sometimes stalled at low revs while driving. I believe it also has a louder and deeper sound now. As I had 15hrs on the bike I changed gear and motoroil, the airfilter and the spark. I removed the cable to the (small) lightmask as it was defect because once before the bike fell down in my garage (due to that ... side stand) and I saw a cable that leads to the o2 sensor not plugged in anywhere and I couldn't see any plug where it could go in... I was told, it isn't supposed to be connected anywhere in a derestricted bike Everything went well and the bike starts at the second kick but I have to raise the idle (my hourmeter shows about 1800 rpm but I don't trust him ;-) ) too high or the bike doesn't rev up as it should and it is much too weak. Please see Has anyone any idea what the problem could be? Edited September 7, 2018 by rob[aut] Edit Quote Link to comment Share on other sites More sharing options...
chatlie44 Posted September 7, 2018 Share Posted September 7, 2018 5 hours ago, rob[aut] said: That sounds too fast. Does the bike pop and bang? If yes you may have moved the exhaust causing a leak. If not check the throttle body hasn't moved and now got an air leak around the inlet rubber. 5 hours ago, rob[aut] said: Quote Link to comment Share on other sites More sharing options...
rob[aut] Posted September 7, 2018 Author Share Posted September 7, 2018 Thanks, I'll check both of your suggestions because at idle it does some kind of "blob" (not too loud) every three or four seconds. At first I'll remove the whole exhaust and fasten it again. Thanks so far 1 Quote Link to comment Share on other sites More sharing options...
ourian Posted September 8, 2018 Share Posted September 8, 2018 Your tick over sounds very fast, your tachometer/hourmeter is not correct, this maybe because the signal wire from the tachometer is too long and in contact with the fuel tank Here are the instructions for de-restricting the 4rt, I suggest that you check that the dealer has made all the changes needed, especially removing the green/white wire from the connector and any restrictions in the throttle body and airfilter. 1 Quote Link to comment Share on other sites More sharing options...
fantic303 Posted September 8, 2018 Share Posted September 8, 2018 (edited) More to read Cota 4RT Full Power Version removal of the restrictions Edited September 8, 2018 by fantic303 Quote Link to comment Share on other sites More sharing options...
rob[aut] Posted September 8, 2018 Author Share Posted September 8, 2018 (edited) Thanks @ourian and @fantic303. I'll check that but I have 16hrs on the bike now and for the first 15 hrs the bike ran great. So the dealer derestricted the bike completely I think Edited September 8, 2018 by rob[aut] Quote Link to comment Share on other sites More sharing options...
chatlie44 Posted September 8, 2018 Share Posted September 8, 2018 15 hours ago, rob[aut] said: Thanks, I'll check both of your suggestions because at idle it does some kind of "blob" (not too loud) every three or four seconds. At first I'll remove the whole exhaust and fasten it again. Thanks so far Try fitting the hour meter correctly to get a more accurate reading too. Quote Link to comment Share on other sites More sharing options...
b40rt Posted September 8, 2018 Share Posted September 8, 2018 If your problem started after a fall, chances are you damaged something to cause the problem. Check all connections, look for damaged/crushed wiring. Re-seal the exhaust to eliminate that, same with throttle body, reduce tickover till it sounds correct. Quote Link to comment Share on other sites More sharing options...
maxwell smart Posted September 9, 2018 Share Posted September 9, 2018 the rpm meter has gone wonky. the first thing that has to be corrected is the setup of the meter for correct operation, that is essential. the 4rt has to be very close to 1800 rpms to operate correctly. scrutinize the meter to see if the button was pushed during its fall and changed the settings/ I think its reading half scale right now. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted September 11, 2018 Share Posted September 11, 2018 (edited) Looking at that video either the bike has been set up with far far too much slack in the cable or something is causing the throttle mechanism not to bottom out on the stop thus resulting in the excessively high tick over and concomitant slack in the cable compared to what you had before. Too high a tickover would also explain the poor starting. Edited September 11, 2018 by 2stroke4stroke Quote Link to comment Share on other sites More sharing options...
rob[aut] Posted September 22, 2018 Author Share Posted September 22, 2018 (edited) On 11.9.2018 at 2:02 PM, 2stroke4stroke said: Looking at that video either the bike has been set up with far far too much slack in the cable or something is causing the throttle mechanism not to bottom out on the stop thus resulting in the excessively high tick over and concomitant slack in the cable compared to what you had before. Too high a tickover would also explain the poor starting. The bike had a high idle because I set it so high to get some power when reving up. Meanwhile I de- and remounted the whole exhaust and it seems to run ok by now. I'll keep u informed :-) Edited September 25, 2018 by rob[aut] 1 Quote Link to comment Share on other sites More sharing options...
martin belair Posted September 23, 2018 Share Posted September 23, 2018 (edited) The idle is WAY to high. Check the throttle twist grip. It may have been moved or damaged in the fall. Edited September 23, 2018 by martin belair Quote Link to comment Share on other sites More sharing options...
