September 11, 20188 yr Isn't the ERT2 gone? I can only find ERT3. The big difference is that it weighs a good bit more than Renthal R1.
September 12, 20188 yr 15 hours ago, b40rt said: Regina chain has proper rivets, so you can add bits in without using multiple split links. In motion sell suitable 1/2 links. Is there a split link option too? I like to pull the chain and throw it in the parts cleaner at work when it gets nasty
September 12, 20188 yr 7 hours ago, turbofurball said: Is there a split link option too? I like to pull the chain and throw it in the parts cleaner at work when it gets nasty Split link as usual. Only mentioned the rivet option if your trying various sprocket combos.
September 12, 20188 yr Ah ok, yes that does sound like the ideal solution! I'm thinking of going up a couple of teeth on the front to 14, since at the moment first gear is pointless and the bike can't do more than maybe 25mph flat out (not great between sections on a long trial)
September 12, 20188 yr 1 hour ago, turbofurball said: Ah ok, yes that does sound like the ideal solution! I'm thinking of going up a couple of teeth on the front to 14, since at the moment first gear is pointless and the bike can't do more than maybe 25mph flat out (not great between sections on a long trial) 1 tooth may be enough.
