250 Rev3
Thanks for the input guys I will sort the bars out. I have also emailed Beta UK with the frame number, hopefully they will give a definite answer. After looking at the history it doesn't look like they changed a great deal.
Rich.
  • Replies 61
  • Views 19.5k
Most Popular Posts
  • Bigusdickus
    Bigusdickus
    Here is the new toy, It looks to be in very good nick for its age engine is smooth, no rattles, has all the gears and has the water pump  problem sorted. I cant believe my luck for a nice little
  • Risers have been long gone, this was a pic when I brought the bike home!
  • Bigusdickus
    Bigusdickus
    Lineawy you were bang on, The yelow wire is the lighting feed from the stator some one has wired the kill switch through this thinking it's a ground ?  .I am astounded that this hasn't killed the
Hmm, that's odd, I don't see the side access cover.
2002 should be side airbox, pretty sure it wasn't until 2003 they moved it to the top
Here's a pic of mine with the airbox cover in the yellow circle
Have you removed the mudguard/fender to see exactly where the airbox is?
 Throw those risers in the trash. You are loosing all the leverage, due to the risers.
Ha ha that was going to be my next question, I am sure it's not supposed to drop that much petrol . ? the angle the carb is at must make it hard to get a decent float height.
Rich.
There's some very useful info there. The bike seems to be running very rich at the moment,  I am not sure if it's flooding or needs leening of a bit. I will have the carb of tomorrow and have a look.
Rich.
Good eyes  Lineaway you are correct it's a 2002. Thanks Gary at Beta UK for the quick response, so two years older than I was led to believe but no sweat it's in good condition for it's age  and I think it's going to be plenty enough bike at this stage of my Trials career.
Rich.
Hi to all.
Last night I was very kindly invited to a practice and training day at Raydon Pit Suffolk. So I got up early and sorted the previously mentioned issues and of I went. Thanks Gary for making me feel welcome. So ten minutes in I am just starting to figure things out when I disappear in a big cloud of steem  ? so after a bit of diagnosis it turns out the fan is not working. Tryed jumping the wires at the thermostat made no difference. So I am guessing the fan is dead.
Rich
Ok so hear come the questions, what sort of voltage should I get at the thermostat. Is it more complicated than just bridging the two thermostat wires to get the fan running? Is it possible the stator is not give enough juice to run the fan. Are the fans still available for a bike this old. Any advice will be much appreciated.
Rich.
I am properly fed up now just seen the price of a new fan, hopefully this will be some thing simple. ?
Rich.
 Just bridge the two wires together. Should just be the thermo, unless somebody screwed up the wiring putting the kill button on.
That was the first thing I tried, unfortunately not that simple. What relation would the kill switch have to the cooling fan ?
the plan tomorrrow is to take the multi meter to it and find out if there is any power. Am I looking for 12v, there has to be a voltage regulator some place not sure where
it is though. I have had a chat with the guy I bought it from he says he is happy to take it back and give me a refund to be honest that may happen as I have had a bad year for
mechanicals, I will update when I have a better understanding of whats going on with it.
Rich.
