January 16, 20197 yr Howdy, I've a fork seal leaking has anyone used a fork seal driver ? I was looking at the Sealey MS016 35mm-55mm Fork seal Driver..I've never done one before but i've looked at a you tube video on it and it looks relatively simple even to my Limited Mechanics Skill Set...it's a Beta Evo Any thoughts ? Best, Mick
January 16, 20197 yr Have a look through this site as there are some different methods employed to achieve the same ends. You will pay a bit for the seal installer set and probably not get to use it very often. Some members have been very resourceful and used other items such as water pipe and scaffold poles suitably cut and modified. An alternative would be to go to your local bike dealer and ask if they would insert the seals for you....less than the driver set.....they might even let you use the installer. Before you go and fit the seals make sure there are no burrs, scratches etc that might cause issues. Silicone grease or rubber lube needs to be applied to the lip seals to prevent them sticking or tearing on the fork tubes.
January 17, 20197 yr I have the one that comes in two halves and you use it as a kind of slide hammer, it works just fine, I have done a few road bike seals (Vmax, XT660) and a Beta Techno and it's done well each time. I would reccomend masking taping the stanchions after you have slid the seal down to protect the surfaces as you hammer the driver up and down.
January 18, 20197 yr I’ve used PVC pipe cut to length with great success (no bunged seals). You have to be careful of the protruding lip on the wipers. I usually take a dremel to the inside edge to chamfer the inner edge of the PVC pipe to clear the wiper lip. Edited January 23, 20197 yr by dan williams Wanted to make clear it's the PVC I'm chamfering
January 18, 20197 yr By the time seals need replacing then I find it worth stripping the forks to clean them - a lot of black stuff comes out. I then use the old seal to drive the new one in.
January 20, 20197 yr Author Thanks for the advice everyone it's a '19 Evo and the fork with the disc on is leaking oil out of the top quite badly. I can't say as it's lasted so long seeing as the bike was new end of last September...
January 20, 20197 yr Maybe just got some grit in there ? might be worth trying to clean it out. There is a special tool available but I`m sure people have made their own from something like a plastic bottle.
January 21, 20197 yr If you don’t ding the stanchions you should get years out of a set of seals. You need to do a careful visual of the tubes. If you have a nick in the tube no seal will last very long.
January 23, 20197 yr Ryan Young used to have an excellent video on changing fork seals on a Sherco with the Paioli forks. It's worth a watch if you can find it.
