Cota 200 exhaust
Have 1983 Cota 200  painted frame , installed used cylinder , , then upon assembly , noticed front exhaust pipe , goes through under gas tank , looked a  cooking was going on there , so stoped , decided to custom pipe outside around ,  so what you all think ,  larry
Edited by larry s. k.
Add pic
 I had a 200 for 18 years building a pipe never crossed my mind. If I remember right the underside of the tank had a protective layer protecting it.
My 348 has a similar thing going on. I think the factory fitted something to the tank that was glued on. it must have fallen off in the 80s.
A previous owner bolted a bit of bent and hammered steel sheet to the frame that acted as a heat deflector. it didnt look very neat but seems to have worked.
sorry no photos as the bike is in bits at the moment.
It might not be the right pipe or it might be a bit bent or the tank might be out of position or it might be the wrong tank
Does the rest of the bike bike look like this?
Edited by feetupfun
