June 10, 20206 yr Hi all , it seems there are lots of different rear shocks out there, some rated at soft and super soft action ect and i am 95 kg so need stronger spring rate to go on the shocks . I would have said you needed stiffer shocks for stronger springs , what do you find works best??
June 10, 20206 yr I’ve got NJB ultimate on BSA C15 and Fantic 240. Personally I find they work very well and I’m 90kg, Now I’m trying to remember if they were soft or super soft, I just rang and gave them the bike and my weight so they could build them. Reasonable price too plus adjustable length. Had a pair of Falcon shocks and likewise rang the company and gave them bike and my weight. They were super soft and were fine on C15
June 11, 20206 yr Depends on bike set up a lot.I am 207 lbs and my ty has the shocks laid down a bit like a majesty which means it needs a stronger spring.Falcon set mine up with 70 lb springs. Sounds stiff but works fantastic.If my shock mounts were not modified they would have used 50,s or 60,s.
June 11, 20206 yr I'm the same weight as you and on my TY250 I've got standard damping Falcon trial classics with 50 lb springs and they are perfect for me. I don't hop the rear but if that is your intention then you would be better off with the superlight damping version.
June 11, 20206 yr Author Thank you all for that , I can now make a decision on what is required, will get some orderd and start removing this monoshock , sam brownlee informs me they used a kwac AR50 shock when they converted it..hopefully will get her back to twinshock asap and working as it should
June 19, 20206 yr On 6/11/2020 at 1:22 AM, feetupfun said: I'm the same weight as you and on my TY250 I've got standard damping Falcon trial classics with 50 lb springs and they are perfect for me. I don't hop the rear but if that is your intention then you would be better off with the superlight damping version. If my shock location was stock it was 50 or 60 lbs but when I told them I did the mod they changed it.I had them do the soft damping as the bike is mainly used for trials in intermediate lines.Been riding it over a year and shocks work nice.I save the bouncing for my TRS.
June 20, 20206 yr On 6/10/2020 at 11:02 PM, timdog said: I’ve got NJB ultimate on BSA C15 and Fantic 240. Personally I find they work very well and I’m 90kg, Now I’m trying to remember if they were soft or super soft, I just rang and gave them the bike and my weight so they could build them. Reasonable price too plus adjustable length. Had a pair of Falcon shocks and likewise rang the company and gave them bike and my weight. They were super soft and were fine on C15 There is so much smoke and mirrors with shocks and so much made of so little... Spending buying the best or most expensive won't bet you on the podium.. I recently did well on my old ty 434 with the original knackeered old shocks that came with the bike when it left the factory in 1974. As mentioned the middle price range are plenty good enough for most riders.. and Norman at Njb had been doing shocks since the war... well almost.. he knows his stuff and you could do worse than giving him a bell.. if not OKO's Betors all do the job or if you want to go up a level Magical Falcons or rockshocks.. but it wont make you a better rider.. Hope this helps.
June 20, 20206 yr 1 hour ago, metisse said: There is so much smoke and mirrors with shocks and so much made of so little... Spending buying the best or most expensive won't bet you on the podium.. I recently did well on my old ty 434 with the original knackeered old shocks that came with the bike when it left the factory in 1974. As mentioned the middle price range are plenty good enough for most riders.. and Norman at Njb had been doing shocks since the war... well almost.. he knows his stuff and you could do worse than giving him a bell.. if not OKO's Betors all do the job or if you want to go up a level Magical Falcons or rockshocks.. but it wont make you a better rider.. Hope this helps. Beauty of rockshocks is spare parts if you damage them, easily serviceable, variety of spring rates if swapping to another bike and you can change the length if required.
June 20, 20206 yr I would use shocks that can be fitted with the right springs upon your weight in combination with the weight of the bike. That is most importand, if you have the right static and dynamic sag most rear shocks will perform right, everything else is less important and less costly in set up. In my experience to find the right spring is the clue.
June 20, 20206 yr Author I have located a set of girling units as fitted originally but these will be saved for now, I have had contact with norman who will sort me out a set as required, with correct spring rates ect.. I am not a trials ace, I could buy more expensive but it's more about period bits !
June 21, 20206 yr If you ask Norman he will paint them in Girling colours.. also Propol in Belgium has made a business refurbing old shocks to something like new. He specialises in Girlings and old knackered ones on French and Belgium for sale sites are being snapped up to be rejuvenised. His range off shocks are good and good value.
