Rebuild a 250 Alpina 1974 type 115
Swimming bike ... Ida went here few days ago.
  • Replies 158
  • Views 38.5k
Most Popular Posts
  • Finally, from (without registration):  To : New  seat New OKO carburator New tires Tank restored  with new petcock New chain and sprockets Bottom engin rebuilt
  • I use a socket with the OD machined down to fit onto that nut. Yes a clutch holding tool is required the way you are doing the work, but if you are going to pull a Bultaco motor apart again, cons
  • Engine is out 🙂, I wish to open it asap but the frame is the priority...
We are back, I  have done the rear fender, tail light and did few things I had to redo by missing spares ...
The space is tight on the chain side for brake, chain cover, chain, Shock Absorbers ...
Next job: set up the alignment seat/ tank/ frame.
Ready for the adjustments: nothing must move with the nuts ( 3: one in front and two in the back.
 Next step will be to review the gas tank : liner, painting,...
I just get the sealing kit for my gas tank:
My tank had a long life before:
I am thinking for the final color like this Triumph 🤫...
I just get the service manual from Ebay ...😉
  • 3 weeks later...
News: I bought a OKO carburetor (they are affordable).
I a still working in my gas tank, inside liner will be done this week (ready for the last phase).
I have the paint for outside, the tank is 90% ready.
I have  a question: do you have a reserve position in fuel valve  ?
Fly wheel is removed, no real corrosion. Electronic ignition is schedule with 12 DC for the light and accessories.
Some fuel taps have a reserve position. Some don't. I couldn't see your fuel tap to know. If you've got the original fuel tap it would be a good idea to use a new (modern) tap instead to get a more reliable flow stream.
When you do the liner, take care to avoid letting liner harden in the threaded hole for the tap. On a couple of the Spanish fibreglass tanks I've lined, the thread required cleaning out of liner and for that I used a thread cutting tap when the liner was solid but not fully set.
whole project looking good!!! did i missed what kind of rear shocks are you using?
I have a 116 just started to get going after more than 25 years in storage...
Gas cap: I will need a new clean gas cap, they seems so expensive 😪.
Do you have a store to go ?
Thanks
Thanks
What's wrong with yours? There's not much to them.
Anyway if you want a new one, In Motion has push-in type Bultaco caps list price 24 british pounds.
If you can bear having the wrong logo on it, the Montesa Cota 348 push-in cap will fit your tank.
A friend uses a rubber foot from a tubular framed bar stool as a cap for his tank.
A nice repainted gas tank with such cap 😏...
