Rebuild a 250 Alpina 1974 type 115
Primer is done, I have seen some impacts to be done before the final color 😁...
  • Replies 158
  • Views 38.5k
Most Popular Posts
  • Finally, from (without registration):  To : New  seat New OKO carburator New tires Tank restored  with new petcock New chain and sprockets Bottom engin rebuilt
  • I use a socket with the OD machined down to fit onto that nut. Yes a clutch holding tool is required the way you are doing the work, but if you are going to pull a Bultaco motor apart again, cons
  • Engine is out 🙂, I wish to open it asap but the frame is the priority...
New ignition arrived today 😃...
Next will be the piston, if needed 😆.
Then I will have all to renew my engine: ball bearings, seals, new connecting rod (by experience, I always change bearings for old bike to prevent a reopening ).
I never keep engine open, you never know what could happen (loose elements, corrosion)...
At first to finish my gas tank, but the temperature drops to winter season 🤥: difficult to paint in such condition.
Thank you, the fuel tap was probably out of service and repair with US thread...
I already ordered the one from Ebay.
Painting is on way, stickers and clear coating to come ..
Exhaust / muffler: not the central part.
This bike seems to be done with a "standard" from the web.
I don't want to put 250USD for this silencer
I love this example, any idea ...🤨
I received the petcock, the gas cap is redone (waiting the new  "O" rings)...
Otherwise I got my new carrier, I did some improvements (lights / Turnbuckles replaced by 2" straps).
It's a very good solid product , but expensive 😒
To come back to previous question, this seems to be the original design:
Original Exhaust for the US.
Cleaning from my workshop for the next phase 😗...
Cooling blade: I will keep as it is (any advices ?).🙂
Top end open: original 72mm diameter.
It looks very clean inside, no scratch, very little carbon deposit: seems to have low hours 😏...
This bike has no head gasket ?
