October 15, 20215 yr Specialy when I use the front brake, I just loosen a little bit my grip the throttle to control the motor or a few times when wet the gloves where sticky enough to open the throttle when I was not carefull enough to really open my hand. The Mechanix gloves I used was the one with the plam covered with rubber with little dots, maybe other kind work better. The trials glove I bought are Jitsie. Guy
October 15, 20215 yr 3 hours ago, guy53 said: Specialy when I use the front brake, I just loosen a little bit my grip the throttle to control the motor or a few times when wet the gloves where sticky enough to open the throttle when I was not carefull enough to really open my hand. The Mechanix gloves I used was the one with the plam covered with rubber with little dots, maybe other kind work better. The trials glove I bought are Jitsie. Guy I use the heatproof ones that are made for working on engines, the palms are made of a sort of suede material
October 15, 20215 yr 4 hours ago, guy53 said: Specialy when I use the front brake, I just loosen a little bit my grip the throttle to control the motor or a few times when wet the gloves where sticky enough to open the throttle when I was not carefull enough to really open my hand. The Mechanix gloves I used was the one with the plam covered with rubber with little dots, maybe other kind work better. The trials glove I bought are Jitsie. Guy Thanks for the clarification
October 18, 20215 yr I use the heatproof ones that are made for working on engines, the palms are made of a sort of suede material ( turbofurball ) That would certanly be good as the trials gloves I bought are also made with a kind of suede material Guy
October 22, 20215 yr I wear off brand Mechanix like gloves but I like the idea of mountain bike gloves. I also read somewhere that water ski gloves work good in wet conditions but I've never checked them out.
