johnnyjazz Posted 12 hours ago Report Share Posted 12 hours ago (edited) Hey friends, any thoughts on this for the reflex? I've installed new EBC grooved pads but rear brake is still terrible! - is re machining the drum a better option? thanks for any insight before i drop some $$ Edited 12 hours ago by johnnyjazz Quote Link to comment Share on other sites More sharing options...
kurtas Posted 5 hours ago Report Share Posted 5 hours ago It takes some time for pads to bed in and have full contact with the drum. You might want to go down the path of having pads of a suitable friction material applied to the brake shoe so you can match the diameter of your drum. 1 Quote Link to comment Share on other sites More sharing options...
johnnyjazz Posted 1 hour ago Author Report Share Posted 1 hour ago Thanks Kurtas, pads have been in a few months - front works OK (and is new too).. im not sure what you mean by 'having pads of a suitable friction material applied to brake shoe'? i thought the EBC were a good choice? i swapped them out from the original OEM that still had some life left in them, but they really sucked, so had expected some improvement with the EBC...just exploring options - hence wondering about that brake extender arm...if there is a better brake pad i can get lmk! i ride on the road so just need something that inspires a little more confidence! Quote Link to comment Share on other sites More sharing options...
kurtas Posted 1 hour ago Report Share Posted 1 hour ago EBC are ok but they are not peak performance which you seem to be after. An example of someone who does it below but you coould find someone who does it for forklifts or the like locally to you. https://villiersservices.co.uk/product/brake-shoe-re-lining-service/ Quote Link to comment Share on other sites More sharing options...
