4RT Clutch Actuation?
mcman56
18 hours ago, Tr1AL said:
The 4RT 301RR makes  a pathetic 16.3 HP , 1 HP more than a VERTIGO 125   but the 301RR puts out 15.1 ft/lbs torque  , where as the VERTIGO 125 makes 8.8 ft/lbs . With that much torque output of the 301 it may be better leaving it with the stock clutch spring set up.
4RT 260 makes 15.6 HP and 13.4 ft/lbs torque
Are HP and torque numbers available for the standard Beta 300 4t, maybe with rpm numbers?  I have one of those too.  In a tight section, the Montesa feels much more powerful so I need to use very little throttle.  I thought it was overall more powerful.  However, the other day I took it to some open trails with good size hills.  There it feels similar to the Beta.  I wonder if there is a real power difference or if the fuel injection just makes it more responsive.
The problem you are noting with the Beta 4T throttle response is they fitted the bike with a CV carburetor. Vacuum operated carburetors rob engine intake vacuum pressure to operate the carburetor negatively effecting both the throttle response and the engine performance, in PGM-Fi fuel systems 100% of the engine vacuum pressure is dedicated to intake of air & fuel, Fi does not exhibit the throttle lag and occasional misfires inherent to the CV carbs normal operation.
On 11/15/2025 at 5:24 AM, lineaway said:
The plate holds the springs straight. They other wise rub
on the towers. The springs are much lighter. Available from Webike.
Why do they rub?  Do the springs have a smaller inside diameter?  Is the plate just slightly thicker with the groove to center the springs.
Want to know what will happen after you put lighter pressure plate springs then required in your clutch <- it's going to slip in high gear ranges, same as if you leave 2 of the 6 springs out.
