mcman56 Posted 20 hours ago Share Posted 20 hours ago There is some kind of white residue primarily on the front wheel of my 2018. It looks sort of like mineral deposits from where water dried. Detergent, Isopropyl alcohol and acetone do not remove it. A carnauba cleaner wax removes some but is way too much work for old hands. The rag with cleaner turns black so maybe it is some kind of oxidation. Is there an easy way to remove it? Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted 19 hours ago Share Posted 19 hours ago 11 minutes ago, mcman56 said: There is some kind of white residue primarily on the front wheel of my 2018. It looks sort of like mineral deposits from where water dried. Detergent, Isopropyl alcohol and acetone do not remove it. A carnauba cleaner wax removes some but is way too much work for old hands. The rag with cleaner turns black so maybe it is some kind of oxidation. Is there an easy way to remove it? Just buy a new rim and get the wheel rebuilt, Its the only way its going to be great again. Quote Link to comment Share on other sites More sharing options...
kurtas Posted 13 hours ago Share Posted 13 hours ago Could try a maroon scotch brite pad Quote Link to comment Share on other sites More sharing options...
faussy Posted 9 hours ago Share Posted 9 hours ago On the anodisation? What cleaner do you use? Sounds like oxidation. Id try some t-cut, cleaner wax doesn't have much abrasive in it Quote Link to comment Share on other sites More sharing options...
mcman56 Posted 5 hours ago Author Share Posted 5 hours ago I use Simple Green on everything. "has a mildly alkaline pH of 8.5 to 9.5." Can that corrode anodize? I have not seen this on other bikes. Quote Link to comment Share on other sites More sharing options...
RonH Posted 50 minutes ago Share Posted 50 minutes ago 4 hours ago, mcman56 said: I use Simple Green on everything. "has a mildly alkaline pH of 8.5 to 9.5." Can that corrode anodize? I have not seen this on other bikes. Simple green is NOT safe on anodized aluminum. It is too alkaline. Just Google the question and you’ll see. I once used it on a red anodized cassette on a bike and it faded it considerably. Quote Link to comment Share on other sites More sharing options...
