dfwilson
Tire (tyre) Pressure?
27 posts in this topic
What tire pressure, front and rear, should I run for different conditions. I weigh 13.5 Stone (230 lbs). I don't want to have a pinch flat but I want as much traction as possible. The conditions I ride range from my concrete patio, in which I place cement blocks, wooden crates, and, what ever else I can find to practice on, to ravines with grass, sand, and, roots. Thanks for any suggestions.
Amateur Section Crash Test Dummy
Share this post
Link to post
i suggest bout 7-9 on rock dependin g on weather conditions, and 5-7 on mud/grass depending on conditions, the drier the higher.
cheers from olly
Share this post
Link to post
4 PSI in the back, 6 PSI in the front, all conditions, certainly no higher than 4 though as you will start to lose grip.
2 people like this
Share this post
Link to post
i agree with t-shock 250 for normal going. i usually drop each down a pound when its really muddy.
Edited by sparky
1 person likes this
Share this post
Link to post
Many variables here, but as the top guys run around 4/5 psi in the rear and hit large rock steps in 3rd that would be fine for you. 5 in a michelin shouldn't give any trouble at all and good traction for a 13stoner.
1 person likes this
Share this post
Link to post
Thanks all, for the info. I have been running 7psi front and 6psi back. I will be brave and lower the pressure.
1 person likes this
Share this post
Link to post
dfwilson - here in TX I run 5 in the front and 4 in the back for most conditions (soft sandy loam, leaves, some rocks, etc.). On the granite west of Austin (Katemcy Rocks) and up in Tishomingo, OK this past weekend we were running 7 in front and 6 in back - I heard of no pinch flats or cut sidewalls. I weigh 180 lb.
Share this post
Link to post
In the rocks I run 7 front and 5 rear
In the mud I run 6 front and 4 rear (I don't go less than that cause you never know when you'll hit one of those rim busting rocks down in that mud. Then as soon as you set up for the mud, they'll throw in a rock section on the loop.
Depends on the tires you run too.
The IRC's seem to have have a stiffer side wall and tolerate the low pressures better than the Michelins. I prefer the Michelins in the rocks and IRC's in the mud.
Share this post
Link to post
I've run as low as 3 psi in the rear on mine, and I'm 200lbs! ;) This is in unusual conditions with slime covered rocks, but never had any problems even running that low...oh, and this is with Michelins.
Normally I run 5-6 in front and 4-5 in the rear.
Share this post
Link to post
i went round the last trial with a puncture on a tubed tyre!! 0psi for 2 laps of 18 including rocks, quarry, loads of burns.... but it was amazing grip on the hill climbs and moor run but not so good when riding back on the forest track, i normally ride 4-5 psi back and 6-7 psi in front, i dont normally adjust the front as it doesnt make much difference!
REV`er ;)
Share this post
Link to post
Not giving any of my secrets away!!  :wacko:
Of course not you might be embarrased to say how much pressure it takes to keep a Montesa afloat. ;)
Share this post
Link to post
Im 20 stone...wat pressures should i be runnin 4rt. Soft clay underneath leaves n roots some road work
Share this post
Link to post
As stated above pro-riders like Bou and Raga are splitting at pressures like 4 rear and 5 front without issues.
so, unless your trail riding and high speeds or riding very jagged rocks you should be fine at a psi of 4 rear and 5 front.
if your concerned maybe 4.5 rear and 5.5 to 6 front but I bet you would feel the difference in traction at that pressure.  And I wouldn't go more that 5 rear and 6.5 front...
Share this post
Link to post
Thanks Jonny. I was just concerned because o my weight on the rear tyre..at 20 stone...Bou n Ragga are guys around 12 stone..im nearly twice their weight. N im not doin sections. Its mainly trail riding with an odd wee play..
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
