This stream auto-updates
  1. Past hour
  2. Not exactly the solution I was hoping for. But yeah, I guess they are not too serviceable.
  3. Yesterday
  4. See de video from a Japanese on you tube whit de new Beta...!!!
  5. Hi, Delighted with my new 250 Sincro but the factory website says there are three variables for the clutch spring tension but no info on how to change them. Has anybody tried it out yet before I take the clutch cover off? Thanks in advance!
  6. Hi All, I just purchased a Beta Sincro but because it is a new model, insurance companies haven't listed it yet. The bike is road registered and DVLA were happy to take my road tax payment immediately even though I can't use it on the road. Any thoughts please? Naturally I am particularly anxious to have the bike insured against theft if nothing else.
  7. On mine I cut a window, repacked and closed it back up with an aluminum sheet metal cover with a rubber gasket and rivets.
  8. Last week
  9. Thank you very much! Got my two TLs today and I'm enjoying them a lot. I will check out the places you listed.
  10. I did do some parts chasing Some TL parts are shared with the XLs. I was able to get intake valves here. https://www.xlintperformance.com/ IMD was selling piston kits on ebay. They were very nicely made. The machinist who bored the cylinder thought they had the original Honda molds. Gaskets came from ebay. A China copy petcock from ebay worked after installing Honda OEM seals. A China copy 22mm carb worked well after increasing the slide cut away. It was well made and accepted OEM Keihin jets but needed the bowl seal replaced. It seems like China o-rings do not like US gas or maybe just California gas. I think All Balls sold a steering bearing kit and fork seals. These guys had the transmission output shaft that the seal runs on. https://www.davidsilverspares.com/ These guys have some general Honda stuff. https://4into1.com/?srsltid=AfmBOoqk_OxNHRz3n01ZkipB_bpjTyDPO1CO1xnau5oSRcIMlS0ChZAQ The main bearings are or were no longer available. They use some kind of custom bearing with a larger OD than anything available. Be sure they need to be replaced before pulling them off. I didn't. All Balls listed a kit but they were just a standard bearing. There are solutions but none are easy or cheap. I replaced the ignition advance mechanism with used parts from ebay. IIRC, they were from an XL125 but looked the same. As mentioned, CMSL has some things too. I could not find an intake manifold so ended up having to machine one.
  11. Yes, Chris said he might start a new class this year. Otherwise the early liquid cooled bikes are legal in the modern vintage class.
  12. I have a 2012 ST290. I looked in the service manual, and there is a reference for removing and re-packing the silencer packing fibers on the newer models However, on the 2012 model, I am not sure this can be done. It is of a different design than what is shown in the manual. On my bike, there IS a philips screw in the correct location that would indicate it is possible, but when I remove that screw, nothing comes apart. Does anyone know if the silencer tube can be removed for cleaning or repacking on the 2012 model?
  13. Bials, here are a few places that sell TL parts. Hopefully you can find what you need on them. https://www.megazip.net/zapchasti-dlya-motocyklov/honda/tl250-14857/tl250-28759/tl250-a-787928?network=x&adposition=&keyword=&gad_source=1&gad_campaignid=22419889174&gbraid=0AAAAADdym2axmanakEDnZRMjcQ5KOwMbQ&gclid=EAIaIQobChMItNiJ08SYkgMVZg6tBh35kzofEAAYAyAAEgI1rfD_BwE https://www.cmsnl.com/honda-tl250_model302/?bg_source=ga&bg_campaign=16511123247&bg_kw=dsa-1465129992666-mi--pi--ppi-&bg_source_id=586686834193&gad_source=1&gad_campaignid=16511123247&gbraid=0AAAAABvnBcJu1N-OSlIKn7IozHy-M-FqW&gclid=EAIaIQobChMItNiJ08SYkgMVZg6tBh35kzofEAAYASAAEgLI0fD_BwE https://www.speedandsport.com/model/tl250/ https://www.vintco.com/shop/Honda/TL250
  14. Thanks Feetupfun, I am definitely going to look to see where the closest vintage trials events are. I might give it a try after I sort my bike out. Higher bars/lower pegs might be necessary. Are you aware of any dealers that might still have TL250 accessories? Thanks. Oh, I'm in the US, but it really doesn't matter.
  15. Thanks. I am sorta set on a TL and might branch out later on. I'll probably be doing more trail riding with my son and grandson than actual trials. I did really enjoy seeing how many difficult objects I could go over as a youngster. I could climb much more difficult terrain than my friends on their higher powered bikes. I'll see what I can do within reason at my age.
  16. lineaway
    Conrod
    Connecting rod comes as a kit. But it is 400 dollars more for a complete crank.
  17. Thanks for the reply. I will still ride my CRF and will probably ride more trails than trials. Ha! I plan to sit plenty of the time on the TL! I broke my tib and fib about 2 years ago on my XR650 but I'm doing pretty well now. It did take almost a year to get back close to normal though.
  18. At 69, I agree that tall bars make things easier on old backs. The TL250 is a heavy beast. I had one and it weighed 250 lbs without gas. It was also a bit short of ground clearance compared to other bikes. It did have a very nice fork. I find that the TY175 is the easiest bike to ride by far. It is maybe 60 or 70 pounds lighter than a TL250, not a whole lot more than a 4rt. It kicks easy, starts easy and turns very tight. Power is slow and very easy to control yet it easily lifts the front wheel to go over things. For a mid 70s 175, It is quite surprising what kind of hills it will go up in 3rd gear. It is not as capable as a modern bike but easier to ride because you are not constantly working the clutch and brakes. Even with modern shocks, its primarly weakness is suspension. When going up a rocky creek bed like they seem to do all of the time in the UK, you feel like a ball in a pin ball machine. But, that may be true of most twin shocks. If you don't do a lot of that, you may really like one. If you are set on a 4 stroke, a Honda Reflex is also much easier to ride than a TL250.
  19. mcman56
    Conrod
    When I bought a con rod kit for a Beta 125, it came with the big end pin. Don't they all? It is basically the inner bearing race. (unless I'm confusing termonology) Beta USA told me people were just buying complete cranks. IIRC, the price was about double but you did not to pay someone for the crank building work. The 125 crank was a little tiny thing with lots of plastic for filling volume. It looked like you needed some specilized fixturing to support it in the press. It was not mine so I took it to a specilized shop. The guy who did the work did not want to tell me or show me how he supported of held it.
  20. Hi Wes. We are the same age and I still ride competition trials. Make sure the bars and pegs layout allow you to ride with comfort standing up. A lot of old trials bikes have relatively high pegs and when they were new, they also had high bars. Modern bars are not as high as the old bars. I find when practicing that I ride for 5 to 10 minutes on trials stuff, then stop riding and sit on the seat to recover. Riding competition can be easier on your body than practicing because you usually have to wait to ride each section, and also on a twinshock you can usually ride between sections sitting down.
  21. feetupfun
    Conrod
    There is no reason to assume that the big end pin will be OK to reuse after a motor suffers a failed big end bearing. When the crankshaft has been pushed apart, the pin can be inspected for damage.
  22. If someone posts something new, it is visible to everyone who looks at the Trials Central forums, whether the topic started recently or many years ago.
  23. Bials
    TL250 Honda rehab
    Anyone still looking at these posts? I might need some help with my TL250
  24. toonarmy
    Conrod
    Hi all, Stripped my Evo 300 factory 2012 down for what I thought was a top end rattle, however found I have a lot of play in the big end on the Conrod. Struggling to find a Conrod kit for the bike, does any one know if there are alternatives (i.e pro x kit that fits the beta 300rr enduro) or similar. New Conrod from Beta is £190, am I correct in assuming the crankpin won't be worn, only the Conrod? Many thanks
  25. I am 74 yrs old and own a 1975 Suzuki RL250, and a 1975 Honda TL250. I still ride, but not trials, just trails with my grandkids. Standing for extended periods is a problem for me at times, but more of a problem is my balance and reflexes. Last May I fractured my left fibula while riding my son's 1978 Yamaha TY250. It was supposed to be a 6-week recovery time, but for me it ended up a 12-week recovery. I did get out a few times after that and look forward to getting out again this year. I live in Pennsylvania, 6 miles in from Lake Erie and the snow has me working on the bikes instead of riding them. I think you'll be fine coming off of a Honda CRF300L. Have fun. LaVern
  26. Hi everyone, I want to say thanks for letting me join. I got my first trials bike when I was a teenager. It was a slightly used 1973 Honda TL125. I rode that thing on the thousands of acres near my house. It's long gone, but I am purchasing a Honda TL250 soon. I ride Honda CRF300L at the moment and enjoy it, but it's time to slow down a little and try the trials thing again. At 67 years old, I hope I can handle standing for so long on the pegs. I don't know how much advice I can give you guys/gals, but I hope you will indulge my many questions. Thanks, Wes
  27. While I cannot answer your question directly, looking through the Bultaco (red) parts book, here's what I found. The 106 needle jet is listed (18.15-020/106) for the following models: Lobito MK III, Lobito MK IV, model 74, Matador MK IV, Sherpa T 250, Sherpa S 100, 125,175, 200 and Pursang MK II & III. The 106A needle jet (76.15-020/106A) appears unique, only being listed for the Lobito model 76 series. Same for the 105A (76.15-020/105A) and 107A (76.15-020/107A) needle jets, specific to the model 76. Your 30mm carburetor 76.15-001 The model 76 float bowl (76.15-003) has the notation; "with lowered main jet". I hope this helps some. You have a very nice-looking model 76 Lobito! .
  28. I’m in the process of rebuilding the Spanish Amal 930 concentric on my 1971 Lobito 175 Mk4. The needle jet is stamped 106A, and that’s what is listed in the owner’s manual as the correct jet. Amal concentrics had long and short needle jets and some jets were for 4 stroke applications, with others being for two strokes. I have seen lots of Amal needle jets for sale that are designated 106, but not 106A. Does anyone know what the difference is? Thanks for any help!
  1. Load more activity
