Past hour
old but new
I can't help you with the wiring but that picture is '' the '' real reminder of my first bike yes a 116 ( 160000295 ), its the first picture of an Alpina with the small push in gas cap and the one piece tank and side cover I see in a long time. Yours seem to have the '' banana '' exhaust as mine was equiped with the small triangle too restrictive one. A real nice bike congratulation. Guy
Today
Look what i found under the stair
Hi Guys Was wondering what anyone can tell me about one of these. its a TLM50 i think from Japan. And was planning to have as much fun as my 60 year old bones will let me. Any info greatly received
DaMoose started following Look what i found under the stair
DaMoose joined the community
old but new
Hello all Hi my name is Hal and I'm 66 years old and own a Bultaco Alpina #116. I have been riding since 1971 and have owned the Alpina for 3 years. I am in the process of rewiring the headlight, taillight. The model year is 1974 and it has a Lucas hi-lo/ horn button combination switch. The headlight is also a lucas unit with red high beam indicator. I have run all new wires on the machine the resistor and diode tests good. Does anyone have a schematic for the headlight? There was also a small lucas diode bolted to the inside of the headlight bucket and that tests no good, was this diode original or did somebody add it in? Also the bike is still on points and condenser I am familiar with lucas wiring and know which wires are Hi and Low. I am trying to get it legal so I can register it, I certainly would not entertain riding at night with a 6 volt headlight. Thank you for any help or insight that you may have. Thank Hal in CT.
Hal started following old but new
Aprilia Climber 280 1993
2x 7075 washers M10 3.5mm
Yesterday
honda TL 125
Grimeca master cylinder rebuild
Having a go at rebuilding a grimeca front brake master cylinder off a 2014 125 beta. Had all sorts of problems trying to bleed it and even bought a syringe to try and reverse bleed it. I managed to get fluid up to the end of the brake hose but not into the reservoir. I ordered a new seal kit and my thinking was just to strip it down, clean everything, and replace the seals. Two questions, the seal kit comes with an O ring which I don’t know where it goes, I know the other two seals but when I’ve stripped it I’ve not seen the O ring. The other question is in the other rebuild kit which you can get has an extra spring which again cannot find it. Mine has the longer spring but not the short one. Not sure if someone has stripped it before and left the parts out. Does anyone know anything about where the O ring and spring goes and do I need them? thanks for any help
blenkie started following Grimeca master cylinder rebuild
Beta Sincro 200
Yes in actual trials terrain and riding at a sportsman level it will be fine, but I bet it does not make it any easier to ride and where it will fall short is on serious long steep climbs that require using max power on the larger displacement version.
While waiting for the titanium screws, new for the Climber.The original unrestored shock absorber works without leakage but is slow. Rather than restoring it, I'm going to test an assembly from a new aluminum Sachs. Shorter than 5 mm, I will raise the fork in its tees to keep the original plate. Lowering the center of gravity can be a plus and this generation of motorcycle had a good ground clearance. To see, otherwise I will make a custom-bound screed. The weight when it drops by more than 1kg. Good for the weight and the center of gravity all this!
Beta Sincro 200
Does the 200cc model have enough power for a 183 lbs. sportsman rider?
ERW started following Beta Sincro 200
Last week
honda TL 125
Hi can anyone tell me how to put electrics E.G. lights/horn/brake light on my 1976 TL 125 wiring diagram would be brill cheers Mark.
chip999 started following honda TL 125
Hour meter for 4rt
Wow.....thank you for this comprehensive and super helpful information. You rock and I can't wait to see and ride it in a few weeks.
chip999 joined the community
Hour meter for 4rt
Give yourself plenty of time to adjust to the bike, many throw the towel in far too early. Make sure you get a workshop manual, they are brilliant. If you plan to keep the bike long term and like to do some tinkering, I’d advise doing a proper PDI on the bike. Grease the headstock bearings, they are lacking in grease and can fail prematurely. (It’s a time consuming job, but do it now and they’ll last for years) Get the copper grease out and do every steel bolt that goes into aluminium to help prevent corrosion and problems down the line. Removing the rear linkage and swinging arm to grease the bearings may seem a big job, but they are easy to do and will again prevent early failure. There is a load of things you can take off the bike to improve the aesthetics and shed quite a bit of weight, you’ll find many things in this forum. The hour meter is a good idea but not necessary, serving really depends on how you ride the bike, a bike that gets ridden hard and often will benefit from oil and filter changes monthly. At the other end of the scale, if you’re just pottering around without getting anywhere near the upper RPM’s then your oil and filter will be good for at least 3 months. The same principle applies for valve clearances. Once they have been adjusted they shouldn’t need doing again. You should never have to change a piston or rings unless you keep it for 10+yeats Do the air filter after every ride, for such a simple design they work well. Remove the flame guard it is not necessary. Remove and clean the throttle body every now and again. The mudguard bolts are made of cheese and wear easily, titanium ones are better but expensive. Taking the air box and throttle body off is much easier when all pipe work and breathers have been taken off and sorted out, all the information can be found on here. The tick over can be dialled back a little without affecting starting too much. Once you get to know the bike you’ll be amazed at the build quality and how everything fits together perfectly. Enjoy
djise joined the community
paul77 joined the community
Montesa Cota 200 (1980) restauration
OK I see, do you know about the value of your build now ? I wish I can restaure mine as brand new to resell it, but idk if there is much buyer for this kind of bike.
Hi, thanks for the reply. What does an AI agent has to do in this kind of forum ? just asking 😁
2015 TXT 300 Starting in reverse.
Hi, There is no adjustment on this model of Gas Gas.
Future
Torrot just went into bankruptcy and they are still 40% owners of Gas Gas. A US dealer is selling brand new bikes for $4000 out the door. Gas Gas has 2027 enduro models so maybe Bajaj will keep the enduro line and hopefully the trials line will return to Spain and be sold to Reiju.
Hour meter for 4rt
I have made the decision to move from 2t to 4t and will be picking up a new 2025 301rr in a few weeks. I want to follow maintenance protocols closely and in line with that, I would like to mount an hour meter somewhere visible, but not in the way. Hoping for suggestions on which meter and some installation tips.
Kschwartz started following Hour meter for 4rt
Manyprojects started following Introduce Yourself
Manyprojects joined the community
Montesa cota 200 1981
Hi all. Ok so I have taken the fork tubes apart and didn't take any photos of them. They were seized up so cleaned them up but, trying to put the lower piston back is proving difficult. The circlip needs to go back in to the bottom the stantion but i cant push the piston in far enough for it lock in place..have i got them the wrong way around???
- Newbie but old😊
Little question about dimple plates
I received the apico dimple plates this week. I have rounded and polished the teeth a little bit. Just because I could. And today I have tried them for the first time. The improvement is huge. Really smooth operation, absolut better control on the clutch. Good update, all together The original plate as it came out Versus the sligthly polished Apico plate The apico teeth, before polishing, looked very similar to the original plates so there is some improvement. I don't know if it makes any difference in operation but it won't hurt either.
smog joined the community
Titanium head bolt. (M14 x 1.50) Next titanium parts are coming ...
Have you tried shifting the pickup coil to retard the ignition? or are they set in position on a GasGas.
Earlier
Seed joined the community
italjet 350t missing parts
Salve ho una italjet trial 350 cc326 del 1986 e cerco parafango anteriore e posteriore verde, mascherina e fanalino, sella nera. Sapete dove posso trovarli?
X-Trial Predictions Competition
The Mototrial X-Trial Predictions Competition will be kicking off very soon. The opening round will be in Madrid on 28 November and prediction entries will open on 7 November. All you have to do is predict the top 3 plus a wildcard. Get it right and you could be a winner. Join now and be ready to put in your entry. https://mototrial.co.uk/predictions/xtrial/
Newbie but old😊
Once you've got the bike built you'll find Gwent Classic Trials Club put on some good trials near you.
