Report Hebo Casual Tshirts in General Trials Talk Posted February 27, 2007 Ring apico uk look on there web site for the number they are the importer for hebo so if you can get them here they will sort you out!
Report Rev 3 Headstock Bearings - Help in Beta Posted February 18, 2007 As copemech say's the only way to get the bearing off properly is to grind it as far through as possible without damaging the shaft then get a chisel and give it a good hit in the slot you have just ground out it will then crack and just pull off. As for re fitting it just drop it on the steerer tube and knock it on using a punch it will not be to tight to get on.
Report New Techno Owner in Beta Posted February 15, 2007 The forks on your bike are paioli and they are both filled with oil not air .The left hand leg has just a spring in it and on the top is the preload ajuster ,the right leg has the damper unit in and no spring the ajuster screw on the top ajusts the compression damping and works on the oil flowing through the valve. If you phone beta uk they will be able to tell you the oil quantity for each leg as these are different! Hope this is of any help.
Report Helmet Choices in General Trials Talk Posted February 15, 2007 As previously said the shoei has to be the best as reguards quality,i have one and it is over ten years old and is still in excellent condition they are as said vented! i also have a airoh this is a nice lid but i will have to see if it lasts like the shoei they say you only get what you pay for.
Report Colonial Wow! in Trials Reviews & Previews Posted February 12, 2007 Yes saw him on it yesterday it was the 125 not sure how he rode it on the road though as i thought he was not old enough yet.
Report Boyesen Dual Stage Reeds in Beta Posted February 12, 2007 I have done the carb mod's to my 8 month old 250 and changed the jets to 27.5 and 145 main, this alone has made the bike run so much better it has taken poppy feel right out of it and smoothened it right out, so much better of the bottom now runs lovely.
Report Upgrading My 315 in Montesa Posted February 9, 2007 I have a second hand but only used once kiehin carb for one of these if interested !
Report How Much Difference Between The 250 And 270 Beta in Beta Posted February 9, 2007 If your thinking of buying a 270 or 250 and doing this you might aswell get a 200 if you are new to trials then the 200 is probably your best bet anyway.
Report Rev 3 Noisy Gearbox in Beta Posted February 9, 2007 This to me sounds like nothing more than clutch rattle if you put it into gear and let the clutch load up if the noise goes this is what it is !
Report Colonial in UK Trials Talk Posted February 7, 2007 The way the weather is looking at the moment it looks a bit as though it might be a bit snow'y here down in the midlands looks as though we are in for qite a lot of so wonder what is going to be like up there!
Report Beta Rev 3 270cc in Introduce Yourself Posted February 5, 2007 Andybetarev3 it sounds as though it is the stator that has gone on your bike to me this is a common fault on earlier beta's tell your mate he wants to send it to west country windings i have used them myself and they offer a good service and quick turnaround. Abuot
Report Smoky Beta in Beta Posted January 31, 2007 As said before it depends on oil type and quality i run 90:1 for multi lap events where the bike never get's a proper clear out and 80:1 on road trials where you get chance to get it properly hot .When you ride road trials most of the time you notice how much better they run so much cleaner !
Report Anti-freeze in General Trials Talk Posted January 25, 2007 Most of the coolant you buy for bikes now is coolant as opposed to anti freeze this is ready mixed all you have to do is pour it in .You have to be carefull with some of the anti freeze's as they are not to freindly to the magnesium alloy's used in a lot of motorcycles! You really need to change it once a year anyway.
Report Possible Dangers Of Unleaded Fuel. in General Trials Talk Posted January 23, 2007 Yes this is one of my pet hates ,it is not so bad on single lap trials out in open moreland say but in these multi lap trials where most peoples bikes never get used over any distances they run so chocked up and they sit there in ques revving them i alway,s end up with a banging headache it p****s me off.
Report Oil Seals? in Beta Posted January 22, 2007 Yes the forks on your bike are paioli and you can get them from lampkins if this is any help.
Report Beta Techno Starting Problems in Beta Posted January 18, 2007 Depending on what oil you are using depends on the mix for good quality semi sinthetic use about 70:1 and for fully sinthetic about about 80:1 to 100:1 depending on the brand & type. 50:1 is too much oil it will be running oily on that mix and never run clean!
Report Wallace Cup in Trials Reviews & Previews Posted January 17, 2007 I see the wallace cup is looming and would like to ride does anyone know please is there mode than the one route ? Thanks.
Report Beta 4-stroke in Beta Posted January 10, 2007 When you look at all the bikes they are all so good now genrally the design of them down to the way they ride but as a total package they all seem to have there niggly faults most of which are easily overcome but for some reason it takes the manufacturers so long to sort them out, problems that go on year after year witout being rectified cant understand why they don't listen to peoples feedback and act on it!
Report Montesa 4rt Carbon Bits in Montesa Posted January 10, 2007 My mate has some silver mitani carbon swing arm protectors going cheap they are second hand but fine and we live in bedfordshire let me know if interested!You probably know us anyway.
Report Shock Mounting To Swing Arm in General Trials Talk Posted January 6, 2007 The progressive action on link suspension is done in the action of the linkages as said on linkless system it is done internally in the shock which does make them a lot more expensive to make. The pro side to linkless suspension really is in the ease of maintenance no bearings to seize up or wear out and nothig to get caught on the rocks and damage like they do on the montesa's always stretching and cracking them!
Report Beta 4-stroke in Beta Posted January 3, 2007 Heard the other day that the bike lacks a bit in the power department not as powerfull as the montesa's this was from person's in the know!
Report Gas Gas Rear Wheel Leaking From Spoke Holes. in General Trials Talk Posted January 2, 2007 Just seal oround the sides of the rim tape don't bother taking it all off job done and you can still tension the spokes simple as that!
Report New Rev 3 Mikuni Carb? in Beta Posted December 22, 2006 Funny from day one had a 03 250 and you could not park that facing downhill otherwise it would flood and be a pig to start. Got an 06 and that does not do it at all park it on any incline and it makes no difference still starts perfectly. this is with a carb as it came from beta no mods so why do some do it and others not,it has to be due to quality control on the carbs!
Report Manx 2 Day 07 in UK Trials Talk Posted December 22, 2006 It is quite a lot of effort in the organising of getting there and the ferry company are a joke with there prices. But the trial all makes up for this it is that good the whole way it's all done etc the scenery the gp week whole place.Was only going to ride the once last year but it was that good i have to go again!
Hebo Casual Tshirts
will sort you out!
