nigel dabster
Posts posted by nigel dabster
  1. No it just provides an extra clearence which does the trick, twigs excluded.
    There seems to be a clearence which allows the build up without block up. The snowball effect doesn't happen, not to sure why.
  2. Does lighter or heavier oil make this problem better or worse? I'm running 10w40 in my '01 290 and have the sticking problem. Will the 70wt help?
    Use atf it will be better, cured? Maybe if you ride it more, but should be better.
  3. I was told by a reliable source that the montesa/honda fourbanger would be ready for freixa and Amos in Scotland, but there is either somr problem with the project or the reliability isn't there, if thats not one of the same.
  4. Here in the south of England it is pretty much a weekly problem, beta actually supply a lifting kit and all makes were affectted even those withstays above, was ever thus!
    Take 2 fat (heavy)M6 washers under each bolt and this should suffice. 3 not usually ness.
    Uncle dabsters tip no. 767 :D
  5. Sorry bob can't lay my hands on it but give me an area of the bike you aren't happy with and I'll try to remember a few, as a stopgap.
    Jay, did you get the package ok?
    I used 6mm plate aluminum, followed johns method and passed the plate down on a stiff wire filler cap to tap hole.
    Holes drilled of course. 1 bolt into plate,2nd bolt through tap into plate then 1st through tap into plate and tighten. From memory used the o ring, as they seemed to seal ok.
    Any help? :D
  6. Tap turnaround was one of the mods we always did regardless of metal or plastic tank. The other 73 mods I will post when I get the list out.
    The plastic tank mod we did was a little mre sophisticated and involves a metal plate replacing the captive nuts inserted through the tank filler cap, works well.
