nigel dabster Posted March 4, 2010 Share Posted March 4, 2010 Rear frame reynolds (?) Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted March 4, 2010 Share Posted March 4, 2010 Rear frame reynolds (?) Nah mate i think it's definately CDS tubing. Quote Link to comment Share on other sites More sharing options...
paulmac Posted March 4, 2010 Share Posted March 4, 2010 (edited) Hey Dabster - love the spider web on the rear brake pedal - I know the brakes are crap on Sherpa's but... Paul Mac Edited March 4, 2010 by paulmac Quote Link to comment Share on other sites More sharing options...
toofasttim Posted March 4, 2010 Share Posted March 4, 2010 Thanks Dabster. Seems there's a boss on the mount. Paul, you beat me to it. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 5, 2010 Share Posted March 5, 2010 (edited) It hasn't been ridden much last few years can you tell? The rear engine to swingingarm bracket is a standard one with the two engine bolt holes moved back to allow the spindle forward. Angled top with file so doesnt look standard. Edited March 5, 2010 by Nigel Dabster Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 5, 2010 Share Posted March 5, 2010 Thinking maybe a fixing at the bottom of this mount to frame would allow forward mounting the pivot as reynolds bike mentioned above? Quote Link to comment Share on other sites More sharing options...
pedronicman Posted March 5, 2010 Share Posted March 5, 2010 On the rear frame of the Reynolds bike that i have seen (different to the one in the picture!) -the swingarm is much longer and goes right up to just behind the front sprocket and has no swingarm spindle, just bosses between the cases and frame. It also has a silver frame and airbox and exhaust like vestys (to be sold on ebay today ) 340. There were 2 different bikes that John Reynolds rode that were modded one after the other. The one i know of is still owned by an ex comerfords employee. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 5, 2010 Share Posted March 5, 2010 On the rear frame of the Reynolds bike that i have seen (different to the one in the picture!)-the swingarm is much longer and goes right up to just behind the front sprocket and has no swingarm spindle, just bosses between the cases and frame. It also has a silver frame and airbox and exhaust like vestys (to be sold on ebay today ) 340. There were 2 different bikes that John Reynolds rode that were modded one after the other. The one i know of is still owned by an ex comerfords employee. I was never sure whether the one I have as above was Reynolds but its possible, and as big john says his name is stamped on the engine from this bike. Would love to see a photo of the swnging arm set up can you get one? My main intrest is how they fixed the back engine bracket? Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 5, 2010 Share Posted March 5, 2010 On the rear frame of the Reynolds bike that i have seen (different to the one in the picture!)-the swingarm is much longer and goes right up to just behind the front sprocket and has no swingarm spindle, just bosses between the cases and frame. It also has a silver frame and airbox and exhaust like vestys (to be sold on ebay today ) 340. There were 2 different bikes that John Reynolds rode that were modded one after the other. The one i know of is still owned by an ex comerfords employee. Vesty's frame is white. Quote Link to comment Share on other sites More sharing options...
toofasttim Posted March 5, 2010 Share Posted March 5, 2010 Thinking maybe a fixing at the bottom of this mount to frame would allow forward mounting the pivot as reynolds bike mentioned above? That's pretty much as far forward as you can go (I think). Quote Link to comment Share on other sites More sharing options...
woody Posted March 5, 2010 Share Posted March 5, 2010 On the Reynolds bike (I'm assuming the last one before they stopped modifying) the swingarm mount, as mentioned before, is right behind the gearbox sprocket, or, in a vertical line, directly under the carb with no through spindle, just located either side to the frame plates. The front frame tube from swingarm up to seat was bent forward as it descends to move the pivot forwards. The rear engine mount has some large bracket work to hold it but can't see exactly how it's done in the photo I have (can't post photos) It must be fixed to the frame somewhere. I see what you mean about the Vesty bike having scalloped rear crankcases now - I thought you meant the crankcases themselves which isn't possible due to the internals, hence my earlier comment, but it is the engine mounting boss that is scalloped away, it doesn't go into the actual crankcase which is what I thought was meant originally. Quote Link to comment Share on other sites More sharing options...
toofasttim Posted March 5, 2010 Share Posted March 5, 2010 On the Reynolds bike (I'm assuming the last one before they stopped modifying) the swingarm mount, as mentioned before, is right behind the gearbox sprocket I can conceive how this was achieved on the sprocket side but how was it done on the primary crankcase side? Sorry Dabster, I was wrong again. Quote Link to comment Share on other sites More sharing options...
woody Posted March 5, 2010 Share Posted March 5, 2010 On the clutch side, the pivot mount sits right up against the clutch case, just above the selector shaft. I'd assume from the way it is done that the engine has to go in after the swingarm is fitted and the engine has to come out to remove the swingarm. Quote Link to comment Share on other sites More sharing options...
pedronicman Posted March 5, 2010 Share Posted March 5, 2010 Vesty's frame is white. Read my post again - i AM talking about the John reynolds bike with the grey frame - not Vesty's bike which yes has a white frame , which is actually situated next to me. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 5, 2010 Share Posted March 5, 2010 Read my post again - i AM talking about the John reynolds bike with the grey frame - notVesty's bike which yes has a white frame , which is actually situated next to me. Sorry yes with the two and's in one sentence I misunderstood. It is impossible to move both pivots further forward than the picture above, the only way I can see it would be possible is with only one pivot gearbox sprocket side. Look at vestys bike and the spindle is almost touching the cases, rhs. The only solution would be a very narrow pivot rhs is that how its done? Wouldn't this compromise stability? Quote Link to comment Share on other sites More sharing options...
